Question about Nokia 6708 Cellular Phone
Bluetooth not getting off
I switched on the bluetooth and checked visible to all.
However its not getting off now and it gets hang whenever I click on bluetooth menu.
    President:
  • 1,884 Answers
If nothing works then backup your data on a PC and then format the phone by dialing *#7370#. it will bring your phone back to the factory defaults. Then you can restore the data. data to include your phone settings as well. pf this too fails then get the firmware re-installed by Nokia Care only.
Posted on Sep 07, 2009
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
How to copy the mobile messages to computer?
One simple solution is to simply forward the message to an email address you use on your computer and saving it to a folder.
There is no option in the Samsung messaging system to "share" the message directly. So to get around that, go to the message, open it, click the menu button, where you can forward to another email address that you can open and save in your computer emails.
Or you can open the message, click menu and pick "copy message text", go into any number of note apps that Samsung has installed or that you can download from the Android market. Paste the message there, then click the menu button in the notes app and pick "share", you will have many options, but pick bluetooth and send the message to your computer via bluetooth. Make sure your bluetooth is enabled on your computer and on your phone.
On your computer go to start, then type in Bluetooth (or go to control panel and pick the bluetooth icon). Enable bluetooth to receive. Go into your Samsung "settings", pick "wireless and network", pick "bluetooth", pick "visible" and either scan for your computer or have your computer scan for your device. When they are connected, you can transfer the saved message to your computer.
Once your Samsung is paired with your computer and you have the hang of saving the message to notes, clicking the menu, click share, click bluetooth, transferring your messages will be quick and easy.
Jan 01, 2011 | Samsung Computers & Internet
I CANT TRANSFER OR RECEIVE VIA MY BLUETOOTH
first check whether your bluetooth is switched on
then check whether you have switched on the visibility of your phone in the bluetooth settings.
You need to set the visibility on if you want to connect and send/recieve files using bluetooth
Aug 31, 2009 | Cell Phones
Bluetooth wont switch on
try to look at the bluetooth menu if it's visibility is ON. if not. you should turn it on so the other pairing devices can read your bluetooth..
Aug 30, 2009 | Samsung J700 Cellular Phone
Bluetooth of my nokia 9300 doesnot detect or get detected by other dvices. No virus. Formatted but same result. Pls help
You might have switched on the bluetooth but kept in hidden mode. try checking the bluetooth setting and change the mode to visible mode. Then your mobile should be detectable by other mobiles
Mar 17, 2009 | Nokia 9300 Handheld
Camera/bluetooth/calender are hanging
you can master clear the system by pressing *#7370# if this does not help then try having the phone's firmware reflash this will help.
Mar 29, 2008 | Nokia 6600
Nokia 6280 bluetooth
sir,u try by going to menu>>settings>.connectivity>bluetooth>bluetooth settings>>bt visibility>>shown to all then restart ur phone after restoring handset then try to turn it on..else there is a fault in handset regarding bluetooth function.
Oct 14, 2007 | Nokia 6280 Cellular Phone
Nokia 6708 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
