Question about LG Dishwashers
I HAVE AN LG BENCHTOP DISHWASHER LD-05AW2. WHEN I SWITCH ON IT IS FLICKERING ON HEAVY AND NORMAL AT THE SAME TIME AND MAKING A STRANGE NOISE BUT NOT WASHING DISHES - ANY IDEAS PLEASE
  • 3,230 Answers
Well problem seems in the Water-inlet valve -
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Good Luck!!
Thanks
Posted on Sep 07, 2009
My lg Le 1415m1 has limited flow pressure have replaced wash pump motor still did not fix
LG LD-1415M1 Support: Find Manuals & Warranty Info ' LG ...
www.lg.com/au/support-product/lg-LD-1415M1
LG ElectronicsProduct Support. Home Appliances; Dishwashers; LD-1415M1. LD-1415M1 ... What should I do Low Rinse Aid indicator lightens up? Why is water not supplied ...
LG ElectronicsHome Appliances; Dishwashers; LD-1415M1. LD-1415M1. Search For ... What should I do when dishes are kept in a dishwasher after a cycle? Are plastic or ...
Nov 19, 2015 | LG Dishwashers
Noisey dishwasher. LG model LD-1204M1. Wasn't this noises when new.
It's hard to tell in the video but what kind of noise is it? Do it sound like it's out of level? I would reach your hand under the dishwasher and screw or unscrew the "feet" to keep it from wobbling. Otherwise, if it's the machine itself, not sure IF you can do anything.
Feb 11, 2013 | Dishwashers
Bought a LG LD 05AW2 benchtop dishwasher second
More than likely it is the electronic control board.
Feb 26, 2010 | LG Dishwashers
LG Dishwasher LD-1403W - loud whirring noise during wash
We had same problem machine same age, had a service person in and the found that the motor was dying. LG wouldn't cover saying that it was normal wear and tear. b
Jan 01, 2010 | LG Dishwashers
I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG Model LD-05AW2 All motors checked and running, Machine goes through a cycle but main pump not spraying.
Impellers in these often break, will need new pump for easy fix or you could try & replace the impeller
Sep 03, 2008 | LG Dishwashers
LG DISHWASHER LD-1204W1
Try turning your tap off a bit till the noise stops but the dishwasher still fills, it can just be due to a bit too much pressure on your water valve.
hpe this helps
Apr 01, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher LD12AW2
You've done every thing the way I would of done it but check the float switch it is located in the front of the tub near the door if this is open it wont allow power to go to the solenoid see if your getting power across this switch and let me know what you find out god luck
Jan 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher model LD-14AT2
normally means not heating check element and use less soap
Nov 25, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG LD12AW2 leaking
The fill switch may be contaminated with soap or debris that makes it heavier and makes it float lower in the water which means more water is required to trip it. Try moving it manually and see if it is hard to move at the top of its travel.
Oct 28, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
