Question about Whirlpool Washing Machines
Whirlpool AWO3761 My Whirlpool AWO3761 washing machine stopped and the red ''door locked'' light kept flashing. I turned the machine off and reset it so I could remove the load. After unplugging I tried to get it to work again, but it is if the water will not enter the mahine. The red light starts flashing again.
Hi we have a whirlpool awo3761/5 when wash is selected it goes to start but then doorlock flashes a nowt happens, i have just replaced with new doorlock this morning and with fingers crossed tryed again it looked promising but doorlock started to flash again and nothing happens pls pls help
Posted on Aug 23, 2010
My whirlpool awo3761/s keeps tripping my electricity when water is inside the drum
I would turn off the machine and unplug from the wall. Water is conductive and if it is throwing your switch you need a professional to look at it. Ring your local washing machine mechanic. Electricity and water are just too dangerous. If you keep resetting your switch and trying to run it, just to have it reset again, you can burn out the switch in the board. My husband did that when the kettle kept tripping it. New switch in the board was about $300.00.
Feb 06, 2015 | Whirlpool Washing Machines
My whirlpool awm 8103/2 locked light keeps flashing and wont wash
I have disabled the electric door lock a week after I owned mine.
Common problem.
May 03, 2014 | Washing Machines
My washing machine stops and the red "door locked" light keeps flashing. Can anybody tell me how to put this right?
door interlock has failed and it wont lock. so the washer safety device will not let it work, replace door interlock by an approved engineer
Oct 25, 2009 | Whirlpool Washing Machines
My Whirlpool AWO3761/S Wont Wash Or Do A Full Spin But A Slow Spin Works Ok When I Start Any Program It Goes As Normal Starts Filling Rotates the Drum One Way Then Stops The Timer Clicks Like It Is...
Sounds like a problem with the door lock, door switch or the door switch actuator. Door lock is usually a single assembly with the switch. Check the pin on the door first. Model # is probably mistyped, won't come up, so can't tell anything specific.
Oct 13, 2009 | Whirlpool Washing Machines
Machine stops, "door open light" flashes door is securely shut.
bad door lock and or harness replace door lock assy and check all connections
Jul 07, 2009 | Washing Machines
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool door lock
    hi
    We have a whirlpool AWO?D4705 washing machine. The red light is flashing to say clean pump.wee cannot find our manual , can you help please?
    Jan 20, 2008 | Candy CNW136 Front Load Washer/Dryer
    Whirlpool washing machine
    Hi, I have the same problem with the same machine! I've tracked it down to a broken belt.
    Jan 15, 2008 | Hotpoint WMA40 Front Load Washer
    Washing Machines Logo
    1,125 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
