Question about Dell Latitude C400 Notebook
Internal Battery Problem?
My new (used) Dell C400 will not boot up. After pressing the power button, the two leds turn green and thats it. No sounds, no video, no fan. Could this be a battery or fan problem. HELP
  • N5MT Dec 21, 2007
    Dell Latitude D600 notebook will sometimes power up. Over past week, it has failed to powerup 6 times. There is no pattern as to when it responds and does power up. Sometimes hitting the Windows key and ON will do it.
    Sometimes hitting the mute vol button and ON will do it, like the last two times it turned on. Other times it turns on with all the lights to the left of the ON button and it just sits there with no display. Have to take battery out to turn it off as well as the AC disconnected.
    Call to Dell support: they recommended the mother board be replaced. Asked if there was any special keys that would make it go into sleep mode, they had no info,
    So at this point, it time to remove some data and return the machine to where I bought it two wks ago. Anyone have a better solution? Thanks. MD
  • 58 Answers
This is what we call a "NO POST" problem. You need to contact Dell Tech Support for this to narrow down the issue to a part. This could be caused by any part that is not letting the computer to power on or boot up. Note: You may need to tear-down the computer for this issue whe call tech support.
Karlox
Posted on Dec 13, 2007
  • Kristoffer Karl Subang
    Kristoffer Karl Subang Dec 21, 2007
    @N5MT, there could be a problem with windows. to fix that, you can try to restore the computer to factory defaults and check if the computer is doing the same symptoms without any added data at all. If its still doing the same thing, then its wise to return the system because you paid for it.
    hope this helps!
    Karlox
Dell c400 latitude has a 1in border around the screen after windows boot up.
Hi poperwog,
The easiest way to determine if this issue is a hardware or software failure is by performing a power drain. Here's how you will do it.
1. Turn off the computer completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press the power button for about 15-20 seconds.
5. Put the battery back in and plug the unit.
6. Turn it on and observe the system.
If this did not work, it is a hardware failure (display issue).
Hope it helps.
Thank you for using FixYa.
Jun 12, 2011 | Dell Latitude C400 Notebook
I got a dell latitude c400 model but someones administrator password is not letting me sign in to the windows and when i try to reset the f11 and/or f11and ctrl together while restarting the pc to try to...
Hi There,
For a Dell you'll want a Dell Windows Operating System Disc. XP, or Vista. Turn on the 'puter and insert the disk. Power off. Power back on and as soon as you press the power button begin pressing F12 repeatedly. This will take you to a One Time Boot selection menu. Choose CD/DVD and hit enter. You'll then see "Press any key to boot from CD". Do so immediately and away you go.
Regards,
Selk
Nov 12, 2010 | Dell Latitude C400 Notebook
My dell latitude c400 does not take a charge do i have to buy a new battery ?
Yes, most likely you may need to replace the battery. Try to get a different cell capacity this time (I do not know if you currently have a 6 cell or 9 cell battery). Once it's not keeping a charge it most likely has a problem.
Hope this helps...
Apr 18, 2010 | Dell Latitude C400 Notebook
Dell e510 won't make it to post
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
If this has worked you have proven that it's not the power supply (it turned on). If you purchased a non dell power supply, you might try this with the original one installed.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Now, close case, plug in all usb/monitor/internet/etc. Power up computer. You'll get an internal floppy drive error. Push F2 (maybe F1) to get into the BIOS settings and go to "drives" and turn off the internal floppy. Save and exit. The computer should boot properly now.
This seems to be a big problem with the e510, my theory is that this one small battery is the root of most of these failures (as these computers usually fail after 1-2 years), not the power supply or the motherboard (heck, when you replace the motherboard it comes with a new one of these batteries...a several hundred dollar piece of hardware, with a $5 battery that will actually fix it).
Nov 09, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Bootup Problem
reinstalll u r window with new partition and try keybord update
Oct 23, 2008 | Dell Latitude C400 Notebook
Power light blinking yellow after sitting a while
Unplug computer, disconnect all usb/monitor/internet, open it, hold power button until green led on the inside on the motherboard turns off, pop out the BIOS battery (looks like a big watch battery and use a small flathead screwdriver to depress the spring lock on one side), plug in computer, hold power button for about 20 seconds (must reset BIOS or something), let up on power button, wait 10 seconds and push power button. The computer should turn on. Wait for it until activity seems stable (1 min. or so). Push powerbutton to shut off.
Go buy a new battery (CR2032 3 volt). Unplug computer, open it, hold power button until green led on the inside on the motherboard turns off, pop in new battery, plug in (you should notice the power button blinking amber again), hold power button until it stops blinking (about 20 sec....again must reset BIOS or something), wait 10 sec., push power button. the computer should turn on. Wait for it until activity seems stabe (1 min. or so). Push powerbutton to shut off.
Oct 11, 2008 | Dell XPS 200 PC Desktop
Dell Latitude C400 PC Notebook
yes the power jack need to be replaced or your power adpoter maby no good any more more likley teh power jack all dells have these heat isses
Jan 23, 2008 | Dell Latitude C400 Notebook
Booting problem
could be a cpu, memory, or motherboard problem.
Dec 09, 2007 | Dell Latitude C400 Notebook
Screen wont show boot screen
fo to bios options by pressing f2 or del soon the power button is released. thre u can find an option to enable silent boot . turn it on
Dec 08, 2007 | Dell Latitude C400 Notebook
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
116 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
