Question about Curtis DVD8017 Portable DVD Player
Curtis DVD8007C says "No disc"
It says loading, loading, loading, while spinning... but then says no disc. How can I tell if the laser is faulty? what does "too low on caps" mean (as said in Solution)? Bought at garage sale, powered up okay, screen is fine, I get a Settings menu just fine, but should've played a CD in it first... :o( Now, I'm just determined to make it work.
If the laser is faulty should I just trash it?
    Brigadier General:
  • 4,090 Answers
Never heard of powered up on caps. But first try using and IRIS cleaner to remove dirt and dust from the laser eye. The disk has a brush embedded in it and is just run like a normal disk. It sweeps the dirt fromm the eye and then SHOULD be able to see it really does have a disk.
Please rate the help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 07, 2009
Testimonial: "Thanks... now I just have to find an Iris cleaner. :o)"
My Curtis 1041 DVD player isn't working .when I insert a Disc it reads "NO DISC", but I've noticed by taking off the cover that it's not spinning "turning",I'm enclosing a photo,thanks for your time .
You have to adjust the laser head, by turning the trimer which is over the laser pcb... if you turn thiw a little, you have to try if its ok. ifits ont try to adjust again until you find the right position of the trimmer...
Oct 25, 2015 | Curtis Televison & Video
My Sony pmc 222v stereo shows "no disc" when a CD is inserted, it does not play. Any suggestions?
Did you check whether the disc spins inside it; after the disc has been loaded? If it does, and still do not recognize the disc; check with an other known disc. If that disc too do not play, the laser pick up unit is faulty, and should be replaced. If the disc do not spin inside the player; after loading it into; the Sled motor [the motor that spins the disc inside] is faulty.
Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 02, 2014 | Sony Video Game Consoles & Games
How do I repair so I don't get "no disc" message?
Could be dirty or faulty laser, faulty decoder board or motor not spinning the disc.
Sep 06, 2014 | Pioneer Elite DV-46AV DVD Player
Shows no disc and does not not spin the disc although there is a disc in the player
Probably dust or dirt on the laser. When so, the laserunit cannot find it's focus. As long as it does not find focus, the disc won't spin.
Clean the laser with pure water (no solvents) by means of a cotton earbud. If the unit is "old" the laser may be worn out. > replace.
The action of focus-finding can be seen by pushing 'play' without a disc loaded. The lens travels up and down 3 times. It will not find focus of course and will announce no disc. Warning: don't look directly into the lens. Laser beam ! By observing this, one can find out if the player really tries to find focus. If nothing happens, there might be a serious fault in the electronics.
Observing laser emission.
By looking sideways on to the laser, one should see some red light in the laser unit. One can also take a photodiode (LD271 f.i) or a phototransistor (any type), connect a DVM to it. Hold the device on top of the laserlens. A few hundred mV should be produced. How much exactly is hard to tell. One can at least monitor if there is laser emission or not.
Mar 12, 2014 | Philips Audio Players & Recorders
My Curtis dvd player 1046 won't play dvd's, it says its loading then it says bad disc
First, try playing a regular music CD and see if that works. Next step would be to get a laser lens cleaner disc and run that in the machine. They come in both CD and DVD styles. You most likely won't get a DVD version to work since it's not reading DVDs, but you might get lucky and get a CD version to work, thus the reason for trying a music CD in the player.
If the cleaning doesn't work, or you can't play a CD either, then something has most likely died. There are really only two things that could go wrong with a DVD player, either the spindle motor (spins the disc) dies, or the laser dies. Both are somewhat common problems on low-end electronics. They can be fixed, but with low-end units, like those made by Curtis, it would cost you less to toss it out and buy a new unit.
Apr 05, 2011 | Curtis Televison & Video
After loading I get either No disk or Wrong disk. Very rarely display works, mostly it keeps spinning with loading on. I tried DVDs, CDs. Same. Cleaning laser did not help. Thanks for assistance....
Hello
You haven't specified nothing about the model number or brand name of you player. Yet i posts this solution, as a common fault symptom. From your description, I assumes that either Laser Picku Unit or Sled motor is faulty. Sled motor is one that spins the disc inside the player. Just open your players outer cover, insert a disc and see whether it spins as it loaded or not. If not replace the sled motor. If it spins, and the Laser Pickup Unit attempts to read the disc from its inside edge to outer, and fails to read the lead-in and lead-out data from disc, laser assembly is faulty and should be replaced with an idetical one both in type and number. In some cases, the strip wire that connects the laser unit to main board may get braked connection prints inside it, which cammot be detected easly. First of all replace this strip wire, and see the effect if disc spins as i indicated earlier. If you wants furthermore assistance, give me a mail, and indicate your need, as I may forget about the solution which I posts to you. gopakumarg43@ymail.com. OK.
Feb 03, 2011 | Televison & Video
Now, when I insert a disc, the player just indicates "loading" and will not play the disc. Just prior to this, it would play the movie part way then "freeze". I couldn't rewind or...
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Certain cleaner disks may not work but the best is to cleaning manually the laser head eye with a cotton bud, very gently and without pressing of the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility that the optical head unit is the suspected fault.
Jan 05, 2011 | Curtis DVD-7600 DVD Player/VCR
I need a replacement battery DVD8007C 7"LCD Protable.
Tries websites like Partstore.com,Amazon.com,Ebay.com to buy the new battery or ask the ventors to buy for a compatible battery.
Oct 28, 2010 | Curtis DVD8007 Player
My Daewoo DVG-5000N does not load the DVD correctly. It tries to spin it up and stops again while displaying that it is "loading". After a while it displays "no disc".
No disc error is usually caused by dirty optical lens or a faulty lens. Turn it off, unplug it, then try cleaning it with a very soft dry cloth and then try playing a cd which has no scratches.
The blue color part, that's called optical lens. It looks like a glass but its not a glass, its a plastic cap for the laser to go thru to read the discs. Never apply any wet solutions on it. Just use a soft dry cloth to rub off the dirt on it.
Jan 16, 2010 | Daewoo Televison & Video
Curtis DVD8017 Portable DVD Player Logo
347 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
