Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Connect wireless printer - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Connecting Hp wireless printer to my Acer 210 tablet
A wireless printer must connect to the wireless router so you must know the SSID & password of your wireless router.
Initial setup must be done fist by connecting and loading the drivers to the PC. Once done you can print wirelessly because you are printing to a networked TCPIP port.
Apr 12, 2013 | HP Photosmart 5514 Wireless e-All-in-One...
Set up wireless
Wireless Method:
  • Make sure your printer has wireless network adapters or a wireless router.
  • Power on the printer and wireless router.
  • Configure the printer to connect the wireless router.
--Enable the DHCP option on the printer. Obtain the IP address automatically.
--Configure the DHCP server of wireless router. Again, assign the IP address automatically.
  • Verify connectivity. Try doing some test prints. If it doesn't work, check the IP addresses.
Network Method:
  • Assign the printer to a wireless network. Go to "Start" and click on "Devices and Printers."
  • Click on "Add a printer".
  • Click on "Add a network, wireless or Bluetooth printer."
  • Select the wireless printer from the list. Click "Next."
  • Allow Windows to successfully connect the printer. Again, click "Next."
  • Click "Finish" to complete the process. If you have multiple printers on your network, set this one as the default. Verify the connection by clicking "Print a test page."
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 14, 2013 | Canon PIXMA MG4220 Wireless InkJet MFC /...
Make Epson Photo RX620 print wirelessly
This model printer has only an USB connection.
It is possible to print wireless by connecting the printer to your computer and sharing your printer on your network that is connected to a wireless router.
OR connecting your printer to a wireless router that has an USB port for connecting a printer.
Aug 04, 2012 | Epson RX620 All-In-One InkJet Photo...
Wirelessly connect to hp deskjet f380 printer
This model printer only has USB printer connection and it cannot be connected to a wireless network directly.
If you have a wireless router then you can connect a print server to this HP printer and then connect the print server to the wireless router. This will allow you to print wirelessly yo the HP printer when you configure the printer server and configure the printer driver in the computers to connect to the printer port IP address of the print server.
Jan 26, 2012 | IBM Computers & Internet
Hello, im trying to install my wirless printer to my wireless computer and im having some difficulties. for example its asking me to check my wireless LAN access point.. I dont know waht that is? im...
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
May 16, 2011 | Canon MP560 All-In-One InkJet Printer
Connecting wireless laptop to wireless printer epsontx600fx using
go to your setup button on the printer (not the computer) and select wireless connection. The SSID should appear automatically. Choose the enter WEP option and enter the WEP for your particular modem. That's it
Jan 16, 2010 | Epson LX-300 Matrix Printer
Connect a wireless laptop to an existing wired network printer
Hi!
Its designed for wireless, but you need an adapter to make it wireless, the adapter
"Dell Wireless Printer Adapter 3310 USB2"
I dont know if that adapter came whit your printer when you bought it, but thats what you need to make it wireless
Good luck
Nic
May 13, 2009 | Dell 5100cn Laser Printer
Cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Apr 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
91 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
