After ten or five minutes uploading at the highest speed that my internet provider allows, the two phone lines shuts down. No light signalization, nobody can call me nor can i call somebody. I have to restart my spa 2102 or limit the upload speed, then after a few minutes it's OK, but sometimes it takes a little bit longer(hours).
Any help would be greatly appreciated. Thank you.
SOURCE: I need to hard rest
dial **** and 73738# and press 1 to confirm the resetting. wait for 1 minute
Whats the provider, sometimes they are provide locked :(
SOURCE: I changed my internet service
You can check the settings of router with below method.
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router.
Then click on WAN settings set it as your internet service provider settings enable DHCP
Then click on wireless and enable it.
. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
SOURCE: I just bought a SPA-2102 NA, is it possible for a
I had the same complaint when my SPA2102 got pass-worded after downloading the sync file from the voip provider. There is a way to find the admin password. Please read information from this link as it will give you an idea as what you should do:
http://forums.redflagdeals.com/setup-pap2-device-3web-voip-server-found-admin-password-494474/
Now I have the admin password after going through the link. Hope this helps others too.
