Hoover quattro door won't open-taken front off-now what?
    Problem Solver:
  • 17 Answers
ARFGRVGCDC
Posted on Sep 07, 2009
The lock on my Hoover Nextra front loader washing machine snapped off when attempting to open the door on completion of wash. Can this be repaired
if it.s the inner door lock catch, that attached to the front door handle
yes it can be replaced, take photo and model number of machine
order from washing machine repair shop. or download manual from malefactors site for correct part number, ,or if you need a repair engineer ring for a quote first, how much will it cost to replace my hoover inner front door catch, good luck
Oct 05, 2016 | Hoover AAA160 Front Load Washer
How can I open the door on hoover Quattro washing machine.
if its a front loader remove lid and plug u can get the door open from top with a long screw driver and a bit of patiace
Mar 01, 2015 | Hoover Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Hoover quattro
Check around the rubber seal at the front of the door. If it is not there it might be in the tank. disassembly required
Aug 26, 2013 | Washing Machines
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Hoover Quattro Whisper 1400 washing machine AE 240 I would like to clean the filter as scum builds inside the rubber seal on the door Cant find the filter, no obvious opening
On the front bottom of the machine there is a plastic 'kick plate' that clips/pushes on. Remove this plate and you will see the filter with a cover secured by a star/phillips screw. Loosen screw and twist this cover off to gain acess. Don't do what i've just done and twist without removing this screw as it breaks it:-(
anyone who knows where i can get a filter cover please post back!
Aug 12, 2010 | Hoover Washing Machines
I need instructions for a hoover quattro 1300 ws130 washing machine
Try checking inside the front right of the soap draw there should be a plastic tab strip with all the settings on it.
You can go to;
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=11
and enter a model number. I believe the manual will be "British"
Are you may have to contact Hoover and have them e-mail the user manual.
Apr 05, 2009 | Washing Machines
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
Washer won't fast spin or drain
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Jul 28, 2006 | Hoover AI130 Front Load Washer
Washing Machines Logo
217 people viewed this question
Top Washing Machines Experts
