Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to
http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
