Question about Tomtom ONE 3rd Edition GPS
How to open tom tom n14644??, usb is damaged need to replace surface mount part. star screws are all out but still case doesnt come apart.
  • Tom Calhoun Aug 07, 2013
    suction cup not holding.
Came apart eventually, click action!
Surface mount USB was a little tricky to remove, got there in the end and resoldered new part on.
If a Usb cable is inserted awkwardly the internal pins can be easily bent and damaged, rendering your device useless, good job i have experience with removing Usb's.
Posted on Sep 08, 2009
My tom tom started with the screen going dull and then volume went lower and it started to shut down then same thig happened a battery symbol of a rectangle shape with a little red section then sat n
can you connect it to your usb port on your computer? if so try to connect and use it. dont worry about charging it just use it to see if its working ok. i dont know why they put a battery that is not replaceable in those. you must send it back to them to replace, I keep mine on power all the time. check this out first and see if its a malfunction or works ok.
Jan 31, 2015 | Navitech TomTom / Tom Tom GPS / SatNav...
Replace power jack
Power supply failures in a HP computer can cause your computer to fail to turn on, to operate erratically or cause certain system components not function.
However, the power supply is one of the easiest parts of a computer to replace.
You don't need any special skills to do this.
If you're nervous about opening up your computer case and potentially damaging a computer component, don't be.
All you are really doing is plugging in power supply cables after securing the power supply.
The process should take 10 minutes maximum.
Shut down your HP computer.
Disconnect the power cable from the power supply on the back of your computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Unscrew the side panel from the back of the case and slide it off.
Newer HP computers may have a case door you can open for access or have access buttons to press.
Look at the back of your HP computer case for a set of four screws near the top of the case. Remove these screws and set them aside.
Carefully slide your power supply out of the mounting brackets and set it on a clean working surface.
Do not disconnect any of the power connectors yet.
Slide your replacement HP power supply into the case and use the mounting screws to attach it to the chassis.
Use your old HP power supply as a guide to connect your new power supply to all the computer components.
Switch the power cables from each device from the old supply to the new supply so you don't miss connecting any cables.
Check that all the components have power cables inserted and the old HP power supply is completely disconnected from the system.
Close the HP computer case and plug the power cable into the new HP power supply.
http://www.fonerbooks.com/r_power.htm
Apr 15, 2014 | HP Hewlett Packard Pavilion Slimline...
HOW DO I UPDATE MY TOM TOM GPS N14644?
Need to update my tom tom. I have no idea how to do it.
Jun 24, 2010 | Tomtom ONE XL GPS
My TOM TOM G920 battery doesnt hold charge for more than 5 minutes i think it needs a new battery I want to know how to replace the battery
QUick and dirty this is how it should go. Might be a little different so use some caution.
1- Remove the 4 screws from the outer corners of the gps unit. These are on the back in the corners.
2- Try sticking a small (JEWELERS/PRECISION) screw driver between the two halves of the case. There are small snap locks around the case, these are what you are trying to get to open up.
3- When you get the two halves seperated do not pull them apart. Look carefully inside you might see wires running to tha back half of the case, check on these and see where they go and what they are connected to. If you are lucky they are just speakers and they will have a quick connect on them.
4- Once you have the case seperated, the battery should be right there, remove the battery and install the new one. NOTE-- IMPORTANT sometimes you cannot get the right battery but you can get the same one but with a different end on it. IF YOU are CAREFULL you may be able to get the end off the original battery and put it on the new one.
Hope this helps you out and good luck.
Mar 15, 2010 | Tomtom GO 920 GPS Receiver
How do I reset my TOMTOM N14644?
Go to TOM TOM´s homepage http://www.tomtom.com/services/
Connect the GPS unit to the PC using the USB2 connection.
You will be given the possibility to restore the unit´s files. This takes a while, but it solved the problem for me.
Nov 04, 2009 | Tomtom ONE GPS Receiver
Hyadraulic clutch fluid squirting out of casing where star shaped ring screw/bolt fixing is. Is this as simple as a failed seal??
Mine did the same thing once. Yes mine was the seal. unbolted slave cylinder from casing pulled apart and replaced the seal. Check the bore to make sure its not pitted or rusty as this will damage another seal once replaced.
Apr 07, 2009 | 2003 Ducati Monster 800s i.e.
Replacing CD-RW/DVD Drive
I own a Presario F730US. I have had it apart many times and it is a difficult case to open. There are several ribbon cables that are easily damaged if you are not very careful. You have to pop up the speaker cover panel as there are case screws under it as well. Once inside you will see the screws that retain the optical drive. Once you remove them it will slide right out and the new one will slide right in. I can not overstate how careful you have to be. If you are not 100% sure of yourself I would recomend that you take it to a repair shop and let a qualified tech assist you. The screws you need to get to are under the keyboard. The whole laptop does not need to be disassembled to swap the drive. Once you pop the speaker bazel and the keyboard you are home free. If you need more help feel free to ask.
George
Aug 03, 2008 | Compaq Presario 700 470024-192 Notebook
Tomtom ONE (4NOO.001) 023289 N14644 FCC ID SALONE IC5767A-ONE
my tomtom worked well the other day. have not use it for 5 days. try to turn it on today, does not work. try recharging for 2 hrs still the same, does not turn on. please help
Feb 06, 2008 | Tomtom GO 910 GPS Receiver
How to replace internal battery
Remove the Front facia surround Undo four screws holding internal works to outside body You will need a T6 star screwdriver for this. Remove internal works from body at the base you will see silver foil covering feel over this you will find 4 T5 star screws securing this remove these and also remove speaker by two locating T8 star screws. Gently remove the electronic board keep all locating cables intact You will then see two T4 star screws holding battery holder remove these and the plastic holder .Unclip battery and disconnect from Pcb Board fit new battery and reassemble. .
Jan 07, 2008 | Tomtom GO 300 GPS Receiver
Tomtom ONE 3rd Edition GPS Logo
1,494 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
