M5122 how to get out memory as it seems you have to remove the whole back of machine. thanks Al
    President:
  • 2,022 Answers
Just remove the single screw from the back side where a symbol or ram mark is there.
Posted on Sep 07, 2009
  • mukhtar21 shaikh
    mukhtar21 shaikh Sep 07, 2009
    just remove the single screw from the back side where a symbol or ram mark is there.
  • mukhtar21 shaikh
Who makes bradford sewing machines.? I need a belt for it
Bradford sewing machines were made in Japan and sold by W.T. Grants
There seems to be little information on the machine.
How to Replace Order Motor Belts
Oct 25, 2014 | Sewing Machines
Reinsert memory stick
Remove the memory stick, get a USB reader that will support that stick...then pull pictures off. Once that's completed, look at the memory stick's contacts, do they seem "dirty"? May need to use a soft pink eraser to get the oxidation off. Also, try compressed air in the camera to blow out any dust that is in there...don't use your compressor, pick up a can from Staples or something.
Sep 09, 2013 | Sony Cyber-Shot DSC-T5 Digital Camera
My laptop seemed to be frozen then it shut off by itself. I tried turning it back on and it sounded like it was booting but the screen stayed black and then the caps lock and scroll just blinked mulitple...
It seems related to hardware. Remove external devices and try again. If not booting then service is probably required. You can try re-seating the memory and try again, you will see panels at the bottom of the unit. The one for the memory is usually the one in the center of the whole unit. This video will show you to remove and reposition memory
http://www.youtube.com/watch?v=D1oTz-F6xME&feature=related
Mar 25, 2011 | Computers & Internet
When I try to make a copy the machine make a screeching noise and a blank copy comes out.
Leave the lid up when you make the copy and see if the light bar moves from left to right when copying. Check the scanner lock knob under the left hand side where the papers come out. Make sure it is not locked. Sometimes the scanners get stuck a lot and can cause blank copies. If it is stuck then you just have to remove the glass and then clean and lubricate the steel bar at the back that the whole unit rides back and forth on. Once that is doene it should work fine. Make sure to manually run the scanner bar out and back a few times so that you can get the whole rail lubricated. Do all this with the power turned off.
Good Luck and Thank You for using Fixya.
If I helped, please let me know via a testimonial today!
Oct 08, 2010 | Sharp AL 1631 Copier
Need new ac power supply plug / the jack plug that goes into my laptop isnt connecting to keep my machine on / emachines m5116.
You will be able to get the DC adapter plug from eBay, and they are cheap around $7
have a look here >>>>>
http://cgi.ebay.co.uk/EMACHINES-M5116-M5122-M5322-Dc-Power-Jack-Socket-PJ13_W0QQitemZ190289528780QQcmdZViewItemQQptZUK_Computing_Laptop_Accessories_LaptopCables_Connectors?hash=item2c4e23c7cc&_trksid=p3286.c0.m14
Regards.
Sep 29, 2009 | eMachines M5116 Keyboard
My m20i seems to turn off by itself when it's worming up and then it turns back on and turns off again after the scanner intializes
Shut the machine off, and unplug it. On the back cover you will see smaller cover,maybe about 4 inches with two plastic tabs holding it in.
Remove that smaller cover, in there you will see 1 or 2 memory sticks. Remove them. Remember which it top and bottom.
With the memory removed, plug the machine back in and turn it on. Let it come al the way to ready.
Then shut off, unplug, reinstall the memory , plug it back in and turin it on. That should fix it. That is a software glitch and that process should resolve it. I have seen that several times.
Dec 07, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
