Question about Dell Photo 964 All-In-One InkJet Printer
When i put sim card into printer it say port not located
    Problem Solver:
  • 30 Answers
How to remove SIM card from LG VX10000
Refer to these additional 4G SIM card do's and don'ts.
Ensure the device is powered off.
From the USB port (located on the bottom edge) gently lift and remove the battery cover.
From the notch in lower edge of the battery compartment, lift and remove the battery.
If necessary, remove the SD card.
Remove the SIM card.
Mar 27, 2018 | LG Cell Phones
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
This pad is phone ready, but it does not have a sim slot to put a sim card in, it only have a micro USB port. how or where do I put the sim card.
Hi Jesse, You do know there's three different size sim cards these days and the small sim card is the same size as a micro usb card, Try it...... CHEERS..
Apr 04, 2016 | Cell Phones
Sat says unplug anything connected usb port as this can affect sat nav but nothing ever been connected also sim card gettiing hot
you need to keep it out direct sun light, if the sim card getting hot maybe the sim card is not compatible to that unit, blow some air through the sim connector port, it maybe dusty, or dirt in the contacts, try a different type of sim card good one like scandisk, or smartmedia memory card, make sure the sim card memory is not maxed out in the amount of memory that the device recommends, some time if it say 4gb dont put 8-64gb of memory in it, it will overheat and may start a fire. if you have problems contact the manufacture for more help.
www.ask.com/mfg.name/customer_service/
www.infolinks.com/mfg.name/FAQ
www.manualsonline.com/mfg.name/make/model/
www.eserviceinfo.com/equipment_type/make/model/service/
www.manuals.webcrawler.com/mfg.name/make/model/service/
Apr 21, 2015 | GPS
I try putting the sim card on the phone and when i put it on the phone say's insert sim
Sir,problem in sim port.clean the sim port with rubber or thinner.
Dec 23, 2009 | Nokia 2600
How do i load my phone sim card into the cannon mp480 printer as
Of course it is to small. You need to connect your phone with the adapter that originally came with it into your usb port
Apr 01, 2009 | Canon Office Equipment & Supplies
Cect P168 not dectecting My sim Card
The "insert sim" error is a common error. Usually it is caused from putting the sim in incorrectly.
Try this. If this is the one with the sim card ports that are on top of eachother than put the sim card in the port closest to the phone with the gold side pointing up.
Insert battery, turn on phone.
On the phone, go to the main menu. Tap phone settings. Tap dual sim settings. Tap to open sim 2. Go back to the main screen.
If that does not resolve go back to phone settings, tap dual sim settings, tap to open sim 1, go back to the main screen.
If this is the type of phone with the sim card ports seperate, insert sim with gold side down in either port. Go to phone settings, tap dual sim settings, tap open dual sims. Go back to main screen.
If this problem persists than either the phone or the sim is defective. Test the sim by putting it in a phone that belongs to the carrier the sim came from. If it works in that phone it is not the sim.
Sep 09, 2008 | Dual Electronics CECT P168 Cellular Phone
Sim card not reading
check putting sim card into other phone..
i think in ur nguage the sim port has not fitted properly ... i think somebody opened the set before while refitting the things he didnt fitted the simport correctly .. sim port is in mis contact .. if you r good at opening set then it s a simple pronlem u only can fix it... just abpve the sim port the circuit board is not in contact with that so just opened it & refit it..
otherwise if u r afraid then visit technician...
Feb 11, 2008 | Alcatel One Touch C750 Cellular Phone
Dell Photo 964 All-In-One InkJet Printer Logo
67 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
