Washer/Dryer Heater issue
I have an Indesit WD 125 T EX Washer/dryer that won't wash when a warm cycle (60 degrees or above) is set. Has anyone run into this and be able to help me troubleshoot and solve this?
Thanks in advance
Arti
  • 15,935 Answers
It appears your dual inlet water valve or timer/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
Electrolux ewx14440w washer dryer will not heat water
Hello - Hot water is most often 10 degrees colder when it arrives at your machine from when it leaves your hot water heater. In general hot water is 130 degrees Fahrenheit (54.4 Celsius) or above. Warm water is between 110 and 90 degrees Fahrenheit ( 43.3-32.2 Celsius). Cold water is generally between 80 and 60 degrees Fahrenheit (26.7-15 Celsius). If cold water is below 60 degrees Fahrenheit (15 Celsius), clothes are unlikely to be cleaned very well. After confirming information and it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a defective timer, temperature sensor, or water valve.
Oct 28, 2012 | Electrolux EW1000i Front Load Washer
Indesit WDL 126 dryer - at end of cycle not draining or spining
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit wd 125 had tripped a fuse switch
So many reasons. Check electronic board, loose cables, power inlet inside the chassie (noise cond).
Jul 27, 2009 | Indesit W 123 Front Load Washer
1s70c indesit condenser dryer still blowing cold after elements replaced
This is most probably due to the thermostats at the rear of the heater failing. There are 2 and must be replaced as a pair.
Jun 17, 2008 | Indesit WA 125 Front Load Washer
Indesit is70 tumble dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 06, 2008 | Indesit WA 125 Front Load Washer
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
