Question about Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System
Water does not drain from machine
Washed a case from a dog pillow and stuffing came out in the machine--now I think I have clogged the drain
  • 68 Answers
After you have cleaned the lint filter run a rinse and spin cycle. If its still not draining take the drain hose of the spigot that goes into the "S" bend of your sink and check that isn't blocked; clean out with pen or stick if need be. While its off try a cycle into bucket to flush it out. If the above doesn't work its the pump that blocked. This requires someone to take the back off the machine, being sure its unpluged, then removing the hoses and cleaning out the offending blockage. Don't run the machine for more than a couple of minutes its not going to pump as this may cause perminant damage to the pump. Good luck
Posted on Sep 07, 2009
    President:
  • 632 Answers
Check these:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
I have a Conservator by Crosley washer (about 6 years old) flawless until now. Water under Tub that is not being spun or pumped out. I did wash a big pillow that was stuffed with poly fill and upon
Hello - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Oct 21, 2012 | Crosley CAWC529JQ Top Load Washer
WATER WON'T DRAIN PILLOW "EXPLODED"
Hi
I would need a little more info like what type of machine and model number
Feb 23, 2011 | Washing Machines
Pillow stuffing messed up my clothes washer. The water wouldn't empty and the spin cylce shuts off. I had this problem once before and the stuffing from the pillow had clogged up something... just not sure...
Your drain pump is more in likely plug..Is on the bottom of machine... You'll have to take a couple of hose clamps off to see inside pump...And you might have to clean it more than once...because all that stuffing is still inside machine..Make sure you unplug machine before working on it
Oct 13, 2017 | Washing Machines
I have a LTF2940ES3 and the water drains slowly and not completely. I get the error code E20 and I have already checked the exterior hose and it is not clogged. I washed a stuffed toy pillow and it tore...
There is a filter in the black hose that goes from the tub to the pump. It must be where the toy stuffing blocked the water from draining. Access the hose through the front bottom panel then remove it from the bottom of the tub to get the filter out and clean it.
Remove the two screws attaching the front bottom panel to the cabinet then slide the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall to access the screws more easily.
Loosen the clamp holding the tub-to-pump hose to the tub to remove it and take out filter. Clean the filter then reinstall it and the front bottom panel in reverse order of the removal steps.
Jun 13, 2010 | Washing Machines
My kenmore 500 series will not drain the water.
the pump is probably clogged with pillow fluff...
Jan 15, 2010 | Washing Machines
Cabrio washer wont drain
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Best of luck :)
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
Vbxr1090b0ww hotpoint washer
There is a large hose that runs from the basin to the pump. I would recommend checking this hose from the pump to the basin.  It is probably plugged in there as well as in the pump inpellor.  look under the machine to find the pump.. White/clearish plastic with 2 large hoses running to it
May 27, 2008 | Hotpoint VBXR1090B Top Load Washer
Error code 20
i think your on the right track but a couple of things you need to know first that model washer wont spin tiny loads or one articles of clothing it has a device in the motor called a tacho generator to balance if you have only a small load it cant sense the balance and most of the time will only rock back and forth second your pump is the most likely culprit if you look in side the washer you will see a seem in the tub next to that will be one of the washer tumblers take the screws out of that tumbler slide it forward there will be a hole there rotate the tub to your right and you will find the hole going down to the drain pump can check it there but i don't think you'll find any thing as that is a larger hole it think your drain pump is now if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water ou of the washer from the drain hose but because of the pillow this might not work in your case.now remove the two screws on the front lowerpanel and pull the panel
Jan 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Westinghouse WWS833ES Super Capacity Top Loading Washer w/ Precision Wash System Logo
142 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
