Question about Compaq Presario Notebook
Unable to install wind. xp.
My bootable cd of xp is booted successfully but no matter what after some time it sows a massage that the computer might be infected from virus and i have scan the whole computer but it don't show any virus..
    President:
  • 2,666 Answers
During the install process delete the current partiotion and reformat. This will clear any virus issues.
Posted on Sep 07, 2009
My m250 netbook won't boot up syas missing boot file
Dear Friend
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
If not then it seems that your windows boot file got corrupted. all you have to do is try using your notebooks recovery CD if you dont have a recovery CD then you have to use the windows installer CD
1 Insert the Windows XP bootable CD into the computer.
2 When prompted to press any key to boot from the CD, press any key.
3 Once in the Windows XP setup menu press the "R" key to repair Windows.
4 Log into your Windows installation by pressing the "1" key and pressing enter.
5 You will then be prompted for your administrator password, enter that password.
6 Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
7 Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Thanks
Gagan Gupta
Is that helpful
Mar 17, 2011 | E-Machines M2350 Notebook
Recovery system corrupted failed to recover from factory default settings
if u r using xp then take xp bootable cd insert it and let it boot the system and ther it will sow u the options 1 if u want to install the xp on harddrive then press enter
2 if u want to repair then press R
press r let it lode the required file then select the drive on which u have installed the xp exemple
c: then type command chkdsk /r or chkdsk /f it start recovering the files
or eles u can go to start- all programes- accesseries-system tools-systemrestore- then select option restore my system to earlier time and then click on next then it will sow you the callender select the earlier date then click ok tab it will try to recover ur system
Mar 13, 2011 | Computers & Internet
Unable to install XP OS to MSI lap top
insert a bootable xp cd into the cd drive and hit enter continuosly...it ll ask to hit any key to continue from cd...hit any screen and follow the onscreen instructions...
if it doesnt works, try this....
u can log in to the setup by pressing del key or F2(depends upon make and model) and change the drive booting order...change the first booting device as CD/DVD and second booting device to HDD...
now it ll prompt you to hit any key to start from CD/DVD....
Make sure you have inserted a bootable XP CD in CD drive....Bootable XP CD's can be created only from another bootable XP cd by taking an image from that cd and writing it back to the cd...you can use NERO Copy disc option for this purpose...it ll create an iso image and you can use only this to write into the disc...
Mar 29, 2010 | MSI Crystal M677 Notebook
Where do i find a boot up disk for my hp pavilion running xp? currently the unit starts to boot and then restarts.
Trying to get a bootable XP CD is difficult if not impossible to purchase. Therefore you might want to create one.
I just recently created a bootable XP CD since I was building a new computer and wanted to be able to boot from a CD.
The following URL is a blog I found that helped me create my bootable CD
Create Bootable XP CD
You'll need an XP CD in order to copy the files to your hard disk and to extract the boot image from.
I already had an XP SP3 disk and didn't need to perform the "merging" like the link above does. I did find and download iso buster (freeware) in order to extract the microsoft boot image file.
I used the Roxio steps to create my CD. My version of Roxio was slightly different so the instructions were not 100% correct but I was able to figure things out.
If you successfully create your bootable XP CD you will still need your license key to install just as if it came right from the factory
Oct 08, 2009 | HP Refurbished PAVILION ZT1180 15 SXGA+...
To install XP by removing Linux cannot boot from XP bootable
make sure it is booting from the cd/dvd drive not the hard drive first
Feb 17, 2009 | Microsoft Windows 98 for PC
Booting problem
Install MS Windows XP / 2003 / VISTA CD setup file (ISO file)
Then
  1. Start the computer with your chosen boot disk.
  2. Change to the cdrom drive.
  3. Go into the \i386 directory on the cdrom.
  4. Run WINNT.EXE to begin the install process.
Nov 21, 2008 | Microsoft Windows XP Professional With...
Unable to run Auto Installation Support CD, or Boot System
Is the new motherboard the same model with the one you have replaced. If so, there should have no problem on it. If it is different model, then you have to reconfigure the software installed such as the driver. your new motherboard surely has the CD included where the necessary software should be installed. But, the problem is that you cannot get to the WindowsXP screen..
Windows XP CD is also bootable.. Now in the bios setup there is a portion there that tells about on how to boot whether in drive a, hard disk or cd. Choose CD and inser the bootable Windows XP. In that way you should be able to get to the XP screen. Of course, you have to restart it to make the necessary changes but before that make sure you have saved the changes youve made to the bios setup.
Now if youre able to go to the main screen, uninstall software that are with your old motherboard and install the new one.
Hope to solve your problem.
Af
Dec 12, 2007 | EliteGroup ECS 761GX-M754(3.0A) Socket...
Installation
insert xp bootable cd
hit delete or F2 to enter setup while starting computer
select boot priority or first boot device as "cd rom"
exit saving changes.
boot only 1 time from cd and then follow the installation wizard steps.
Nov 16, 2007 | Computers & Internet
How to install XP on pre loaded Vista in HP Laptop what can i do
make sure you have taken all the backup of your data from your system bcoz xp will not overwrite on vista you need to be format your drive which will erase your data. for installing windowx xp you need win xp cd as well as all the driver for win xp bcoz the driver is diffrent for vista and win xp . if you have windows xp bootable cd just place in your cd-rom or in dvd rom .and go to bios setup (bios setup is just press the del button from your keyboard or f2 key it is display whrn you start your system )and change the booting sequnce from hdd to cd rom when it will boot from cd one massage will come press any key to continue just press the space bar and follow the setup instruction . if you need more help let me know bye
Sep 28, 2007 | Microsoft Windows XP Professional With...
System is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Aug 14, 2007 | Intel Motherboard
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
