Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Morningn when i switched it on the power itself is not coming is it the problem with adapter or the swithc
Sounds like it could be the power supply. How old is the pc? It might just need replaced.
Posted on Sep 08, 2009
When switching headlights on only park lights become on. what could the problem be?
check the switch pull back or forwerd wich ever way the high beens come on see if high beems work if so stil possibly bad switch could be a relay another thing u can do check see if power is at head light with test light
Apr 05, 2014 | 2008 Toyota Yaris Sedan
ZEBRA ZP500 SWITHC TO OFFLINE BY ITSELF. ANY GUESSING?
Check if you don't have a problem with the panel or switch.or your computer sending a ZPL code to switch the printer to off line state
May 18, 2011 | Zebra Z4M Printer
My battery cheges when win XP is shut down or hibernating. But after power up, the battery does not charge, monitor keeps flickering and swithcing between "low power" brightness and "normal" brightness.
Try removing the battery from the laptop & see if it will power up. If not, then you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 06, 2010 | Computers & Internet
The machine switch itself off, and sometimes can not switch on!
It is most likely coming from your power adapter (Power Pack). Have a good electrician check it out for you or replace the power adapter with a good one
May 25, 2010 | Toshiba Satellite A205-S4617 Notebook
My laptop swithces off itself every 40 minutes
This is typical of a overheating (thermal shut down) CPU problem.
When the CPU overheats and shuts down, it won't bootup again until the CPU cools down. If this is not fixed then the CPU will fail.
This problem is caused by either a faulty fan or the fan and heat assembly is clogged with dust.
Check the fan to see if it spins freely, replace if faulty and clean the dust off the fan and heatsink assembly.
Also apply fresh thermal paste to the heatsink/CPU.
Sep 29, 2009 | CMB T43 750 Notebook
It wont turn on, like is the turn on swithc the
Its your phone. Read the User Guide that came with the phone. If you know where the switch is and the phone does not switch on then your switch may be faulty, have it repaired. Or the battery may be absolutely dead. recharge it. Or the phone itself may be dead. have it checked up.
Jul 30, 2009 | Sony Ericsson Z530i Cellular Phone
C920 turns off wont turn back on.comes on when on charge but when charger is removed phone turns off
Friend the power swithc of the phone is shorted. use an electronic tester to solve it. replace the power switch if possible
Jul 10, 2009 | Sony Ericsson Cyber-shot C902 Cellular...
Software problem
try to put charger to phone and see whether it shows charging. if it shows charging than you can power on after a while. are if you have removed battery without switching off the phone to change sim card, than most probably your phone's software got crashed and you need to visit sony ericsson service point.
Dec 24, 2008 | Sony Ericsson K810i Blue Smartphone
Unable to swith off
do a manual restart then swithc it off the usual way, to do a manual restart you hold down the black menu button and the top power button for 5-10 seconds it will restart with the apple logo on the front then once it has come up with the slider hold down the power button until it switchs off.
Oct 03, 2008 | Apple iPhone Smartphone
Wont Switch on
Test power in its adapter up to the plug in end of the switch adapter. The power adapters are usually the culprit. If there's power in the wall plug, that leaves you with the switch itself. It's either bad inside or should come on.
Nov 17, 2007 | NetGear FS605 (FS605SE) Networking Switch
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
23 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
