Question about Cell Phones
Handset wont switch on. Tested battery - all ok. Removed battery, sim and memory card. Still completely dead.
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Sep 29, 2016 | LG Cell Phones
My 12 month-old Android Jellybean will not read SIM card, has removed some apps and will not load downloaded apps into phone memory or CD card
I would recommend backing up the device and then resettings to factory defaults, sounds like your software may be corrupt.
Settings > Privacy > Storage > Factory data reset.
Feb 28, 2014 | Cell Phones
Sony ericsson died and wont switch on
It's likely that you need to reflash the phone software to your phone. You can do this yourself [detailed instructions and files at se-nse.net] or just do it at a phone shop or through an online site like Da Vinci or Wontan.
But something you should try is to remove the battery and take out your SIM / memory card and then let it sit for a bit before you reinsert the battery [withouth SIM / memory card] and restart the phone. Hopefully that'll work, if not then you'll probably have to reflash the phone software. But you could always check by doing a software upgrade using SEUS [Sony Ericsson Update Service offered for free here - http://www.sonyericsson.com/cws/support/...
Jan 12, 2013 | Sony Ericsson T707 Cell Phone
I put my sister's memory card into my phone, to transfer music onto her phone. After I took out her memory card, & inserted mine.. My phone was messed up & had no bars.. & it said it was out of...
turn on the handset fully. Take out the battery and leave the battery out for 30 seconds to a minute. along with the sim card. Replace the sim and battery and turn the handset on again. should be fine then
Jan 14, 2011 | Samsung Comeback Cell Phone
Nokia n73 dead
Hi there, remove the battery ,memory card & sim from the phone. Then fix again battery and sim card. After that confirm, your battery is charged. Then on your phone. If its working , then you sure that, your phone is ok. Now off the phone and put the memory card back on your phone, then turn on again the phone. If that time not working then your memory card is a cause of your dead phone. If your phone dead with out using memory card, then the operating system of your phone corrupt or an internal damaged happens. In that case your must visit Nokia service center. Do not try at home for resolving the phone hardware or software problem. Because some mistake can make a loss of your phone for life time.
Thanks & waiting for your feedback.
Feb 14, 2010 | Nokia N73 Cellular Phone
My nokia was working fine then its screen went blank and now it is doing nothing....totally dead...help
Hi Friend,
Please find the below mentioned steps and kindly follow the steps,
1.Switch off the mobile.
2.Remove the sim card,battery and memory card.
3.Hold the switch on button for 20 to 30 secs,
4.After that replace the sim card and the battery.
5.Now switch on the mobile,
6.After it has switched on now replace the memory card.
Regards,
Ayyasam
Aug 26, 2009 | Nokia N95 Cellular Phone
I lost the phone and when I found it the battery was dead. After a little bit of charging the phone would only come up with a white screen that says "SGH-T339" but wont go past that.
My step son had the same issue. I removed both the SIM card and memory card from the phone before turning it back on. Once the phone got past the "SGH-T339" screen it tells you to install the SIM card. Remove the battery and install SIM card and turn phone back on. It has worked ever since.
Dec 09, 2008 | Samsung SGH-T339 Cellular Phone
Sim card removed battery Completely dead
plz check the battery,if it is ok then your phone needs to be serviced
Jul 23, 2008 | Nokia N95 Cellular Phone
Cannot switch on W880i
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250276275225&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dm38%26_nkw%3D250276275225%2509%26_fvi%3D1
Jul 05, 2008 | Sony Ericsson Walkman® W880i Cellular...
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
