Question about HP LaserJet 3050 All-In-One Printer
Procedure of send fex in hp3050
How send a fex in hp3050lejarjet all in one printer
pls help me
  • 45 Answers
You must first configure time&date and fax header
for time & date:
1. On the control panel, press Menu.
2. Use the < or the > button to select System setup, and then press .
3. Press Menu to select Time/Date.
4. Use the < or the > button to specify either the 12-hour or the 24-hour clock, and then press .
5. Use the alphanumeric buttons to enter the current time.
6. If you specified the 12-hour clock, use the < or the > button to move the cursor past the fourth
character. Select 1 for A.M. or 2 for P.M., and then press .
-or-
If you specified the 24-hour clock, press .
7.
NOTE Make sure that you use two digits to specify the month and day, in that order (for
example, use “05” for May and “01” for the first day of the month of May).
8. Press Menu.
for header:
2. Use the < or the > button to select Fax setup, and then press .
3. Use the < or the > button to select Fax Header, and then press .
4. Use the alphanumeric buttons to enter your fax number, and then press .
5. Use the alphanumeric buttons to enter your company name, and then press .
to send fax:
1. Use the alphanumeric buttons on the all-in-one control panel to dial the number.
If the fax number you are calling has been assigned to a one-touch key, press that key.
-or-
If the fax number you are calling has a speed-dial entry, press Phone Book, use the
alphanumeric buttons to specify the speed-dial entry, and then press .
2. Load the document into the automatic document feeder (ADF) input tray or on the flatbed
scanner.
3. Press Start Fax. If the pages that you want to send are in the ADF, then faxing begins
automatically.
4. If the all-in-one ADF sensor detects that no document is loaded into the ADF input tray, Send
from glass? 1=Yes 2=No appears on the control-panel display. To send the fax from the
flatbed scanner, press 1 to select YES, and then press .
After you press , Load page:X Press appears on the control-panel display.
5. If you have already placed the document on the flatbed scanner, press (or place the
document on the flatbed scanner and then press ).
After scanning the page, Another page? 1=Yes 2=No appears on the control-panel display.
6. If you have more pages to scan, press 1 to select YES, and then repeat step 5 for each page of
the fax job.
-or-
If you are finished, press 2 to select NO.
all the steps are in the manual starting at page 67 here:
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf
Posted on Sep 07, 2009
  • 256 Answers
You can get the detail information for setting up and using the fax from the following link. Pls read the article cerafully toknow how you can setup and use the fax.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=1140783&prodTypeId=18972&prodSeriesId=1140783&objectID=c00659224
My hp3050 machines farmatter not working TAJINDER SINGH
You need to go to Nearest dealer.do not try yourself.
Feb 05, 2011 | HP LaserJet 3050 All-In-One Printer
I have a hp3050 laserjet . I can't seem to send
you need to install the full software solution, you can get it from www.hp.com, on newer operating systems, as Windows 7 this option is not available at all
Apr 06, 2010 | HP LaserJet 3050 All-In-One Printer
I am trying to send a Fax but keep getting a communications error
Vonage is a DIGITAL phone service. ALL fax machines are analog devices. You need a plain old telephone line.
Jul 22, 2009 | HP LaserJet 3050 Printer
HP3050 scan to pdf can't be opened
agalier is not alone. I have exactly the same issue with my HP LaserJet 3050 and pdf files. Once file is opened on PC than did the scanning and saved with a different name, voila the new file can be accessed without problem by another PC on the network. Bizzare!
Jul 30, 2008 | HP LaserJet 3050 All-In-One Printer
94 Acura Vigor
timeng belt fex
Jun 07, 2008 | 1994 Acura Vigor
Faxes sent through HP 3050 is unreadable
Following could be the reason behind this issue:
1. Check ink cartridges of the recieving printer.
2. Make a copy from your printer,if there is any problem while copying then replace the printer.
3. If the copying is not fine then clean the scan feeder, andif it is fine then it is an issue wih the other printer.
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
114 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
