Question about Garden
My stihl chainsaw has been running great in the past years
My stihl chainsaw has been running great in the past. A little hard starting but once you got it going it was fine. I started using the saw this season and it just quit running. I replaced the plug and checked the spark and found it to be weak. Still blue but faint. I cleaned the coil contact and the flywheel but still the same. I checked the compression and found it to be fine. I checked all wires and connections and they were fine. After trying to start it I checked the plug to see if it was loaded with gas, but it was dry. After geting frustrated with it I tried a little either and it still would not start.
    Sniper:
  • 61 Answers
Try this. all stihl machines have a fuel filter on the end of the fuel line inside the tank. if you get a hooked peice of wire you can hook it out through the petrol filler cap. these are very fine and may not looked blocked. you can remove the filter element from its holder to clean it. you can also try the saw without the filter for a short time to see if this is the problem.
Posted on Sep 07, 2009
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
What is the best chainsaw for a female to use, need easy start, no electrical?
None, they are too dangerous. You need strong arms in case of kick back.
But if you must, a national and well known brand like Stihl or Husquvarna. The Stihl MS170 might suit you.
"I am very satisfied with every aspect of this saw and love how light weight it is. It starts easily and runs great. I have cut up to 16 inch diameter oak, and it did a great job, considering the size of the saw. The local dealer was very knowledgeable and very helpful."
-Dick44
Kelseyville, CA
The STIHL MS 170 is the perfect lightweight chainsaw for homeowners seeking a great value. Compact, lightweight with just the right amount of power, the MS 170 makes quick work of trimming or cutting small trees, fallen limbs after a storm, and other tasks around the yard. And even at its great price, the MS 170 has many of the same design features the professionals depend on.
http://www.stihlusa.com/products/chain-saws/homeowner-saws/ms170/
Please make sure you also get the safety gear. Vibration proof gloves to stop 'white finger', hard hat, visor, ear defenders, and most importantly chainsaw pants which has carbon fibres to jam the chain rather than cutting your leg off.
http://www.stihlusa.com/products/protective-and-work-wear/chain-saw-protective-apparel/
Homeowner Chainsaws Mid Range Chainsaw Features STIHL USA
Feb 14, 2016 | Garden
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
Stihl 015 chainsaw
Adjust the air/fuel mixture. Look at your owners manual or online because it gets a little tricky because of climate changes.
Aug 12, 2014 | Stihl Garden
Cranking new chainsaws
The newer saws have emissions regulations that they have to comply with.
Jan 09, 2014 | Husqvarna Garden
Re: Stihl 038 Mag AV. When following the operators manual starting for a cold start, my saw can a be very ugly beast. Quite often it will misfire and the starting cord will recoil so violently that it...
I would check the magneto key in the crank,could be sheared,allowing the timing to advance causing the firing of the spark before the piston reaches the top,hence the violent pullstart
Nov 02, 2013 | Stihl Garden
Stihl chainsaw (Farm Boss) - chain oiler has stopped working, how do I check the fault ?
Hi John...
You will need to remove the bar and chain...behind the bar is the auto oiler it works on the shaft of the chainsaw, you will have to remove it and clean all the outlets for the oil to the chain.
Please take time to rate me
Bud
Mar 10, 2013 | Garden
Stihl 038 super av starts hard, once started runs great till its warmed up then dies and wont start
check the seals on the crankshaft for a leak and the ignition module for a loss of spark as it warms up.
Dec 07, 2012 | Stihl 038av Case Buffers Caps / Plugs 2...
Stihl 025 doesn't have full stroke on pulling the the sarter cord, pulls about a foot then stop after many tries can get the full stroke, runs fine once started
has a knot got in? has it been out more in the past as someone mite of re tried it as for damage just to get going, three turx screws will let you in and have look it is easy, good look
Apr 11, 2012 | Garden
My Poulan chainsaw is hard to start and will not re-start once it is warm. Any suggestions besides junk it.
Spend $ 40 for a tune up at a local chainsaw seller/mechanic. Most Stihl outlets are very good. It sounds like carburation needs adjustment, but they also do a good visual inspection. Mine get done about every 3 years worth of use. HTH
Lou
Sep 29, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
151 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
