Question about Zanussi WJD1667W Front Load Washer / Dryer
Indesit after you set a program programer keeps going around
  • tomi25 Dec 09, 2007
    my indesit wi101 programer keeps going around and the light keeps flashing
    New Friend:
2 red flashes and 3 green wat would this indicate?
Thanks
Jo
Posted on Jun 06, 2016
Help
Posted on Oct 09, 2008
  • 75 Answers
Hi there first of all check your filter located at the front of the machine for blockages as this is a comon fault, failing that next time the dial clicks round count the amount of times the red light flashes before it does a pause then starts again, and let me know how many flashes it does as this corasponds to a fault code
murdozzz
Posted on Dec 09, 2007
Indesit IWC6105 Keeps filling with water and lights flashing
Almost certain to be a power pcb failure due to the fact it fills and drains at the same time this is a regular fault symptom on indesit laundry appliances. Word of caution tho inde pcb's are generic to a range and the software must be programmed via a lap top to your specific appliance so you can't just order a pcb and pop it in sorry
Dec 08, 2013 | Indesit Washing Machines
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
WASHING MACHINE WON'T DRAIN - DIAL KEEPS TURNING AT END OF WASH
Possible failure of the program controller as it fails to contact and supply voltage to the drain valve/pump. So it keeps on moving around.
Try to clean the contacts if not you will need to replace. Also check if there is voltage to the drain valve/pump during the drain cycle, if so the valve/pump is clogged or faulty.
Jan 10, 2011 | Indesit Washing Machines
Wont let me set program just beeps when pressing program so wont run ( indesit dishwasher
Hi. Are you still having this problem? I just experienced exactly the same thing with my D61 for the second time and eventually I just got cross and held down the P button for a couple of seconds and the machine beeped 3 times and the green light went out. I was then able to select the program as normal. Then, it froze on me again so I held down the button again, it reset again and I tried it on a different cycle. Now it's actually going through the cycle. It's so random (the first time I didn't hold down anything and just shuffled stuff around inside for a bit and then it worked ) it seems to be a actual fault with the programmer, so I can\t say for sure that this will work on yours or even on mine again but it's worth a try!
Mar 04, 2010 | Indesit 24 in. D61 Free-standing...
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Indesit WDG1095W combined washer/dryer - program wheel stopped
I'm a bit confused you posted under Bosch but you specify Indesit, which is a UK machine. The really bad news is you need to replace the timer. the really really bad news is you can only buy the timers from Indesit, I can't find them anywhere in the US. The really really really bad news is they want 117.99 british pounds for them! plus shipping and handling. Here is a link to the Indesit site where you can purchase one.
http://www.4indesit.co.uk/cgi-bin/product.pl?PID=111846&query=Indesit%20WDG1095WG&model=WDG1095WG&path=52691
May 22, 2009 | Bosch Exxcel WFO 2264 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit WD10, when program switching from rinse cycle after program number 8 to fabric softner, the switch/nob starts to click around all program numbers. I have replaced the program switch twice in the...
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 25, 2008 | Indesit Washing Machines
Washing machine
this indicates a fault unfortunenately it doesnt say which one the most likely problem will be brushes in your motor
Jan 01, 2007 | Indesit WA 115 Front Load Washer
Zanussi WJD1667W Front Load Washer / Dryer Logo
196 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
