Question about Canon PowerShot A95 Digital Camera
Digital camera fell into fresh water and wont work
Digital camera fell into fresh water and although immediately dried out and new fresh batteries installed it will not work
  • dspriggins Sep 07, 2009
    batteries and memory card removed almost immediately and placed opened up on a car bonnet in the sun. It was a hot day, about 40 degrees centigrade so drying conditions were good. No free water was seen in the camera at the time. Is there anything I can do to restore it to working? Is it worth taking to a repair specialist?
  • 3,230 Answers
Unless you had immediately removed the battery and memory card from the camera and then shook the camera vigorously, maybe you would have had a chance to "save" your camera. Put the camera in a sealed bag and placed it in the sun with uncooked rice in the bag, you would have gone a long way toward saving your camera.
Good Luck!!
Posted on Sep 07, 2009
  • Mukesh Kumar Sep 07, 2009
    There is nothing you can do with.....
    Yes this camera worth repair...........
Canon customer
Maybe.
Did you fish it out immediately, removed the batteries, rinsed it in fresh water, then let it dry thoroughly before even thinking about trying to turn it on? If so, it MIGHT work again after being dried. Otherwise you may as well give it a good funeral and get a new camera.
Aug 22, 2014 | Canon PowerShot A560 Digital Camera
My camera fell in sea water
My sympathies. If you immediately fished the camera out, removed the battery, rinsed it in fresh water, and let it dry thoroughly before even thinking about putting the battery back in and seeing whether it turns on again, then you MIGHT be able to salvage the camera. Otherwise it's time for a new camera.
The pictures on your memory card should be okay. Just rinse the card in fresh water and let it dry before trying to read the card.
Feb 19, 2013 | Sony Cyber-Shot DSC-W220/B Digital Camera
Water damaged
It may have been recoverable, but you damaged it further when you tried to turn it on.
If you had fished it out immediately, removed the batteries, rinsed both camera and batteries in fresh water, and then let everything dry out thoroughly before even thinking about putting the batteries back in and turning it on, the camera MIGHT have worked.
Apparently you just shook it dry and tried to turn it on, right? If that's the case, you may as well give it a good funeral and get a new camera.
Jun 21, 2012 | Canon Cameras
My Sony DSC-T77 fell in the water 2 days ago. What will i do? Is there a possibility that it would still work? Pls help. Thanks
DO NOT TRY TO TURN IT ON! Remove the card and battery....try to dry out those compartments. Bury the camera in a bowl of uncooked rice for one week. Insert the battery and, with fingers crossed, try to turn it on. Even if it works, you may still have a problem with a haze over the lens elements when the water dried. You didn't say if the water was fresh or salt. If it was saltwater, the salt will continue to corrode the internal circuits of the camera.
May 30, 2011 | Sony Cyber-shot DSC-S980 Digital Camera
Fell in water
DO NOT TRY TO TURN IT ON!!! You will only fry the circuits. Remove the battery and card. Dry the compartment as well as you can. Bury the camera in a bowl of dry rice for one week. Then, you can try to turn it on (keeping your fingers crossed). Even if it works, you still have the problem of water marks on the interior lens elements. Also, I'm assuming this was fresh water and not salt water.
Apr 28, 2011 | Casio Exilim EX-Z750 Digital Camera
Flip camera fell in water at the mouth of the river... water was part salt and part fresh... soaked camera in fresh water for an hour or so after then let dry... plugged it into my computer... but...
Drying a camera involves burying it in a bowl of dry rice for a week before even attempting to turn it on. However, your camera was exposed to so much water, there may be no hope for it.
Aug 19, 2010 | Cameras
Camera mmersed in fresh water
Electronics and water don't mix, you have ruined the camera, take the batteries out, take the camera completely apart and dry it completely, this may be ruined / lost cause but you can try.
Sep 06, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Camera fell in the water for 3 seconds, wont turn on
The best advice is to check with Canon, describe what happened, and take their advice. I think you will do best if it is seawater, or saltwater, to return it for servicing, as salt is deadly to some camera parts, and if you switch on with salt water in, it can cause permanent damage to circuits, and even can create a short between components, particularly the flash circuit. If it is fresh water, and for some reason you don't want to return it, it is best to use a hair dryer on medium or low heat to blow dry as much as possible, with the lens off, and the battery and card compartments also open, and come back to it after about an hour and repeat.Do not heat it to anything more than about skin heat, as evaporation will continue at even room temperature. Do this for most of the day, and leave it for a day or two, or even a week, as open to the air as you can, but in a dust-free environment, preferably in a warmish place, like an airing cupboard, so that all moisture will evaporate, Then try it again with fresh battery. I suspect that if it still won't operate, you could repeat the process, but it is most likely then, that you will have to return it for servicing or repair. I had an Olympus C8080w, and me and the camera were swamped by heavy spray from a wave, and I ran to the local shop, bought some tissues, and dried it immediately. I took it home, zoomed out, dried as much as possible down the lens gap, and left it in warm room. When dried out, some salt crystals were left on the lens barrel on zoom out, but thank the Lord, it still worked, and has not let me down - I did use a damp hanky to try and absorb as much water as possible from the outside, and dilute any surface salt as much as I could. I still use it regularly, but dropping into water is a different matter. - Please post and let us know what happens - and the best of luck
Nov 25, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
My Camera in water
Usually when cameras fall in water, the circults gets wet and mostly causes a short-circuit which causes the components to fail. If the camera fell in water without the battery you could try
1. Drying it completly before putting on the battery to test it.
2. Immerse the camera in alchol complety. It basically substitutes water (removes moisture) and vaporises quickly. Dry it completly and test it with battery.
If the battery was in when you dropped it your chances are less. You could dry it completly and show it to a technician ASAP. Make sure no moisture reaches it.
Hope its still under warranty.
Oct 22, 2008 | Pentax *ist DS Digital Camera
Camera fell in water,wont work. It doesn't come on. How do i fix it?
be sure to take the battery out immediately after any electronic item gets wet...also check into the possibility of using alcohol, like rubbing alcohol of low water content to help dry....my brother used it on his cell (batter and sim card removed)..he dipped it and shook it out a couple times and let it dry....started to work fine....havent tried it myself tho...he is an electronics engineer and said water will cling to alcohol and alcohol is not bad for electronics...I am doing more checking on this
Jul 02, 2008 | Cameras
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
