Question about Toshiba MK1637GSX 160 GB IDE Hard Drive
Hard Disk Problem
Failure Predicted on Hard Disk 0:
  • 20 Answers
That failure is predicted by the SMART reporting system. Its a status chip on the drive that reports to apps that can read the smart data from the hard drive. Its not always accurate but it usually is.
Time backup your data on that drive ASAP and then buy a new drive.
Posted on Sep 07, 2009
Testimonial: "thanks, you're a big help"
  • 558 Answers
Back your data up and replace the hard drive.This is new technology that allows the drive to monitor itself and report to you failures.
Good luck
3 Suggested Answers
SOURCE: SMART failure predicted on Hard disk 2: toshiba
back it up immediately, the software on the HD has detected something failing, and it is telling you it is time to back up that drive, and replace the drive, these reports, are usually 100% right.
Posted on Feb 17, 2010
SOURCE: how to fix SMART Failure predicted on Hard Disk 1: Toshiba mk2555gsx?
smart failure predicted on hard disk toshiba MK3265GSXN
Posted on May 23, 2013
Hard disk failure
Purchase a new hdd NOW! and copy your data off while it is still there. You may be lucky and be able to use CloneZilla to clone the failing hdd saving you hours of uploading drivers etc.
Feb 09, 2016 | Lenovo G550 Laptop
Smart failure predicted on hard disk repair
This means either your hard disk is about to fail or it already has in which case you will need to purchase a new HDD (hard disk drive) and then contact acer to purchase recovery disks or if it is still under warranty then contact for service.
Jul 19, 2014 | Acer Computers & Internet
How to resolve problems (smart failure predicted on hard disk 0 : toshiba MQ01ABD050 - (S1))
Copy all the data from the drive to another drive because this one is predicted to fail very soon. Format the drive. That might work, but unlikely since SMART is a hardware problem and format is more of a software driven solution. It has some elements of a hardware issue, but not enough to fix most SMART problems. A low level format might help, but that is not a DIY.
Jul 12, 2014 | Computers & Internet
Acer hard disk failure
Check this site linked here to get more details about the faults with hard disc to Acer, and replacement procedure to the same. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 11, 2013 | Computers & Internet
Failure predicted on hard drive disk 0
A predict failure is just that. There is a good chance it fail. Make a backup and replace. You can also turn the SMART monitoring off in BIOS if you don't want the warning.
Dec 24, 2012 | Acer ASPIRE 5610Z2273 COMPATIBLE LAPTOP...
SMART Failure Predicted on Hard Disk 0: WDC WD3200BEVT-75ZCT2-(S1) WARNING: Immediately back-up your data and replace your hard disk drive. A failure may be imminent. Press F1 to Continue
just means its time to backup all your information, as if the hard drive does fail theres a good chance you may lose some or all of your information.
hard drives aint that expensive around 30 pounds +
and you can replace it with any sata hard drive.
Jun 17, 2012 | Western Digital Computers & Internet
Hard disk failure
try to remove hard disk and then again connect it
Oct 19, 2009 | Computers & Internet
SMART failure predicted on hard disk 0:
There is a big problem with newer conponents and Win XP versions prior to SP2. Especially with newer motherboards.
You have to make a bootable SP2 disk if you don't already have one. To do this use the slipstream proceedure specified on the Ms website. Many other websites describe the process with easier language.
Slipstreaming is a common practice now. Essentially, you copy your original install disk to the c: drive then download SP2 to C: drive then download the slipstream utility from MS. Running the slipstream utility then inserts the proper drivers (ide and HD drivers too) into the licensed copy you have. You then create a bootable disk from the slipstreamed files you have.
This approach is resolving alot of blue STOP errors and SMART errors.
ALSO, you want to make sure you are installing any drivers provided by the MB manufacturer AND Drive maker.
Good Luck
Jul 29, 2009 | Computers & Internet
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Toshiba MK1637GSX 160 GB IDE Hard Drive Logo
1,747 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
