Question about Ryobi Saws
How to test the motor - Ryobi Saws
  • garry1958 Sep 09, 2009
    the motor is on a Ryobi ETS1825 saw bench.
    The supply voltage is 230v and fuses blows has soon has motor is switched on.
    Is there a diagram of the motor windings I can get or a supplier in UK for a new one.
  • 2,176 Answers
I don't know what we are testing for but you need a volt ohms meter and I would unplug the tool and remove the handle half. Test the cord to the switch and then engage switch and test thru it, Remove the brush caps and brushes and test from the switch to the brush holders if you have continuity thru all these look at the condition of the commutator thru the brush tube and rotate the blade by hand and look for major discoloration or the raising of a comm bar. Check the condition and length of the brushes for the spring being collapsed. That would be a good way to start, but if you can give me some idea what you are looking for I will try and help more, I would also need the exact model number and brand.
Posted on Sep 07, 2009
I replaced the blower, and resister on my 2012 chevy. impala but blower still don't work. What fuse do I need to check
The fuse box should be under the hood, passenger side. Try the upper box, middle right side Mine is huge, 30 amp
Sep 23, 2016 | 2012 Chevrolet Chevrolet Impala LT
Tip
How to Hot-Wire Test a Cordless Drill Motor
<span><span>The power switch may not be the problem if a cordless drill stops turning on. Sometimes a bad drill motor can prevent the tool from starting, even if the switch is good. </span></span><br /><span><span>To determine the problem, the best method is to remove the switch and then hot-wire the drill motor to the drill's rechargeable battery to test it. If the motor checks out, then it's probably the switch. </span></span><br /><span><span>The steps for testing a drill motor .</span></span><br /><span><span>In addition to tools needed for dismantling the cordless drill, such as a drill/driver, <b>two</b><b> wires</b> are needed to connect the motor wires to the drill battery. </span></span><br /><br /><span><span><span style="text-decoration: underline;"><b><a></a></b></span>Hot-Wire Test a Drill Motor</b></span></span><br /><span><span><span style="text-decoration: underline;"><b><br /></b></span></span></span><br /><p><span><span>1. Remove the drill's battery and dismantle the drill.</span></span><br /><p><span><span>2. Disconnect the wires leading from the switch to the drill motor. Sometimes this means completely removing the switch. </span></span><br /><p><br /><p><span>3. Now that the motor is isolated from the switch, <b>connect </b>one of the <b>motor </b>wires <b>to </b>one of the <b>battery </b>contacts <b>using one of the two wires</b> set aside for this test.</span><br /><p><br /><p><span><span>4. <b>Connect </b>the <b>second wire </b>to the other battery contact. </span></span><br /><p><span><span>(<b><i>Note:</i></b> It does not matter which motor wire is connected to which battery contact. The orientation is not important because it is a DC motor and will only determine which direction the motor spins.)</span></span><br /><p><span><span>5. Hold the motor firmly in one hand, and then <b>complete </b>the electrical <b>circuit </b>between the battery and the motor by connecting the second wire to the the second motor wire.</span></span><br /><p><span><span><b>If</b> the <b>motor does <i>not</i> spin</b> once the second connection is made, <b>then the drill motor</b> <b>is most likely fried</b> and needs to be replaced. </span></span><br /><p><span><span>If the motor <b><i>does </i>spin </b>after completing the electrical circuit, that's a good indication that <b>the motor is</b> a <b>healthy </b>one. If the motor tests out OK but the drill is still having trouble starting up, the problem is most <b>likely </b>caused by <b>a faulty power switch</b>, not the motor.</span></span><br /><p><br /><span><br /> </span><br /><span><span>The power switch will have to be reconnected to the drill after the motor has been tested. It is important to reinstall the switch wires correctly after performing this test. </span></span><br /><span><span>The example drill used in this article has a very simple wiring configuration in its power switch. Drawing a switch wiring diagram is especially useful for switches with complicated wiring configurations.</span></span><br /><br /><span><span>If you're testing your drill's motor, chances are that some kind of part replacement is on the horizon. </span></span><span><span></span></span>
on Nov 13, 2010 | Drills
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
A/c blower motor works if I pull power and plug back in until I cut engine off. Then I have to repeat process
Daryl, You may want to check the blower relay/ just switch with one of same type and try and if OK, problem could be the blower motor, wires/plug loose,damaged,burnt or a faulty blower motor resistor. Second link has some trouble shooting of a overheating wire problem, that is to be common in these trucks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY 2003 Silverado Blower Motor Resistor
Sparkys Answers Chevrolet Silverado Blower Does Not Work On Any Speed
03 Silverado heater fan problem ChevyTalk FREE Restoration and Repair Help...
Jul 19, 2016 | 2003 Chevrolet Silverado 1500
HOW TO TEST A BLOWER MOTOR
To test the motor windings, use a multimeter to ohm out the common wire wtith the remaining wires of the motor, youn should read resistance, if you read OL on your meter the windings are bad. To test for a short to ground, check the resistance between each motor wire and the motor frame, you should not read resistane ifnyou do the motor is shorted to ground. To test mechanically, spin the shaft by hand, it should move easily, if hard to turn replace the motor. You can also apply power directly to the motor and if it does not start replace motor. Hope this helps
Dec 11, 2012 | Dayton Gas Furnace Heater
I HAVE A NEW KEY I HAVE NO POWER WILL NO COME ON WHEN PLUGED IN
test the fuse and replace, reset the c. breaker and try again
2) test the power cord.
3) test the drive belt motor, for worn, or adjust
4) test the input voltage motor, if there are the motor need repair
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 21, 2012 | Weslo Exercise & Fitness
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
Jul 19, 2011 | Kenmore Ovens
2003 Suburban heater fan will not working.
three things left to check,
using test light see if you have power at motor with key and switch on,if you do replace motor,if not locate blower motor resistor it will be close to motor,check for power going in,last is the heater control assembly
Dec 10, 2009 | 2003 Chevrolet Suburban 1500
The motor is not spinning the basket
Hi..
If the motor is not spinning you need to check this following:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor cupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Regards
PCmania
Jul 14, 2009 | GE Washing Machines
Vw passat 2000 1.8t front wheel drive
please rate me solved...thanks
DTC P0411/16795: SECONDARY AIR SYSTEM - INCORRECT FLOW DETECTED
Test Requirements
Ensure all fuses are okay, battery voltage is at least 11.5 volts, all electrical accessories are off, A/C is off.
Ensure engine is mechanically sound.
Test Procedure
NOTE
Secondary air system is activated by ECM and blows air into exhaust pipe
upstream of catalytic converter for 100 seconds during a cold start, 41-91°F (5-
33°C). Engine must be cold to perform following test procedure.
1. Ensure fuse and secondary fuse (secondary fuse is 40 amp and is located in fuse holder on top of battery)
are okay. Check hoses and components of Secondary Air Injection System, for damage, loose fit and
improper installation, check vacuum hoses for Secondary Air Injection System. Repair as necessary.
Erase DTC memory. Verify repair. If DTC does not reset, test is complete. Perform ECM relearn
procedure. See TEST DRIVE RELEARN PROCEDURE .
2. Remove engine cover. Disconnect pressure hose from Secondary Air Pump Motor (V101), by pressing
buttons on hose connector. See Fig. 33 . Using scan tool, check Secondary Air Pump Motor (V101) in
scan tool Output Diagnostic Test Mode (Secondary Air Pump Relay activation mode). See OUTPUT
DIAGNOSTIC TEST MODE .
3. Secondary Air Pump Motor (V101) should run in intervals and air should exit pump at hose connection.
If Secondary Air Pump Motor (V101) is okay, go to step 7 . If motor runs and no air exits secondary air
pump motor, replace faulty Secondary Air Pump Motor (V101). Erase DTC memory. Verify repair. Test
is complete. Perform ECM relearn procedure. See TEST DRIVE RELEARN PROCEDURE . If
secondary air pump motor does not run, go to next step.
4. Disconnect Secondary Air Pump Motor (V101) harness connector, install LED test light at secondary air
pump harness connector terminals. Turn ignition on. Using scan tool, activate Secondary Air Pump Motor
(V101) in scan tool Output Diagnostic Test Mode (Secondary Air Pump Relay activation mode). See
OUTPUT DIAGNOSTIC TEST MODE . LED test light at Secondary Air Pump Motor (V101) harness
connector should flash. If LED test light at Secondary Air Pump Motor (V101) harness connector does
not flash, go to next step. If LED test light at Secondary Air Pump Motor (V101) harness connector
flashes, replace faulty Secondary Air Pump Motor (V101). Erase DTC memory. Verify repair. Test is
5. Using DVOM check resistance of Secondary Air Pump Motor (V101) wiring. See appropriate WIRING
DIAGRAM under ENGINE PERFORMANCE in SYSTEM WIRING DIAGRAMS. Resistance should
be a maximum of 1.5 ohms for each reading. Check wiring for short circuit to one another in Secondary
Air Pump Motor (N101) harness connector. Repair as necessary. Erase DTC memory. Verify repair. Test
Secondary Air Pump Motor (N101) wiring is okay, go to next step.
6. Check Secondary Air Pump Relay (J299) and Secondary Air Pump Relay (J299) wiring. See DTC
P0418/16802: SECONDARY AIR PUMP RELAY (J299), MALFUNCTION . Repair or replace as
necessary. Erase DTC memory. Verify repair. Test is complete. Perform ECM relearn procedure. See
7. Disconnect vacuum hose from Secondary Air Injection Valve (N112) and disconnect pressure hose from
secondary air pump motor, press buttons on pressure hose connector to disconnect pressure hose. See Fig.
34 . Blow lightly into disconnected pressure hose, Combi-Valve should be closed. Connect hand vacuum
pump to disconnected vacuum hose and apply vacuum to Combi-Valve, Combi-Valve should open. If
Combi-Valve opens when vacuum is applied, Combi-Valve is okay. Go to next step. If Combi-Valve
does not open when vacuum is applied, replace faulty Combi-Valve. Erase DTC memory. Verify repair.
Test is complete. Perform ECM relearn procedure. See TEST DRIVE RELEARN PROCEDURE .
8. Check Secondary Air Injection Valve (N112). See DTC P0412/16796: SECONDARY AIR
INJECTION VALVE (N112), ELECTRICAL CIRCUIT MALFUNCTION . Repair as necessary.
NOTE: Do not use compressed air to check Combi-Valve.
2000 Volkswagen Passat GLS
2000 ENGINE PERFORMANCE Self-Diagnostics - 1.8L Turbo
Jun 21, 2008 | 2000 Volkswagen Passat 4Motion
Saws Logo
251 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
