Question about Technics Audio Players & Recorders
I have a SL-Q5 turntable, after hocking it up to the soundsystem it plays but no sound is coming out from the speakers ... what could i be doing incorrectly?
  • 69 Answers
Are you putting the left and right ( white and red ) phono connectors into the phono inputs on the back of the amp? thats the place to locate them. either that or the leads from the turntable are both damaged but i doubt that is the cause? check your inputs on the back of the amp to see if it has phono inputs? if not you might have to insert them in the auxillary input and buy a small pre-amp from a hi-fi shop to boost the signal? good luck
Posted on Sep 15, 2009
I need to know how to hock it up to a su-z780 amplifer and a sl-b280 turntable?
The turntable should connect directly to the "Phono 1" input. There might be an additional ground wire on the turntable that usually connects to a ground terminal on the back of the receiver.
May 07, 2016 | Audio Players & Recorders
Amp turns on but no output
1 make sure its hocked up properly .2 see i if the protection comes on.. with out the speaker wires hocked up if it does the u have a bad amp.3 if the amp protection light is off with out the speaker being hocked up and after hocking up the speaker it comes on the u have bad wiring to your speaker or a bad speaker
Jun 14, 2013 | Jl Audio 500/1 Car Audio Amplifier
Poor sound quality from a technics SL-D210
Generally either a faulty connection to a lead or cartridge. Or a faulty Cartridge. If you switch the left and right channels of the phono leads the missing sound should move to the left and the right come to life. If it does not then there's a fault in the magnetic cartridge pre-amp in your amp.
Mar 29, 2013 | Technics Audio Players & Recorders
Turntable only playing in one speaker
In my business I work on a lot of turntables. Specifically, Memorex, Anders Nicholson, Innovative Technology and Emerson. 99% of the time when I only have sound coming out of one channel it is due to a broken cartridge. If you look at the tone arm head from underneath you will see a rubber fork that the needle arm sits in. There are usually 2 ceramic cartridges attached to the rubber fork. Those transmit the sounds from the needle. If one of those brakes then that channel will not transmit any sound.
Dec 07, 2011 | Technics SL-1210 Turntable
I have 2 technic sl1200s and the right table has noise coming out of the speaker when i moved the tonearm. when music plays, it sounds like the treble and volume of the right speaker is weaker help...
If your left technics sounds good, maybe the problem is the cartridge. Try to interchange the cartridges, right table cartridge by the left one, and listen. If now the bad sound comes from the left table, it´s time to get a new cartridge or stylus. If the problem continues there is something else to look for. Hope this will help. Flavio/Brazil.
Sep 17, 2010 | Technics SL-1210 Turntable
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Record only plays through one speaker
If it works on Channel One it is NOT the TT. It's a mixer problem. Define the mixer and what else works or doen't work. have you tried another device on Channel 2?
Apr 30, 2010 | Technics SL-1200MK2 Turntable
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
Dec 18, 2007 | Technics SL-1200M3D Turntable
162 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
