Question about Apple iPhone Smartphone
Flashing apple logo
I got my iphone 2g from a friend, when I try to charge it the apple logo
just keep flashing but there are times the USB cable come out and
then it goes back to flashing apple logo. Can somebody help me please
to figure what could be the problem of my 2G, or if anyone experienced
the same problem like mine.
My i pad is stuck in sleep mode
Perform a hard reset: Press both the Power and Home buttons and hold them down. Keep holding both buttons down until you see the Apple logo appear on the screen. The logo should appear between ten and twenty seconds after you start holding the buttons. After the Apple logo appears, your iPhone or iPad will boot back up normally.
Charge your iPhone: Connect the iPhone to the iPhone's USB power adapter and let it charge for at least ten minutes.
Get iPhone into Recovery Mode: Turn off you iPhone and just plug the USB cable into computer > Hold the HOME button when you connect USB to iPhone > Release the HOME button when you see the iTunes logo.
The Most Common iOS 9 9 2 1 9 3 9 3 3 9 3 4 Problems and Solutions
Aug 17, 2016 | Apple iPad (16 GB) WiFi Tablet PC
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Hello, My Iphone is completely dead. The battery went down and I was about 2 months without using it. Now I'm trying to unlock it but the Itunes doesn't recognize it. The screen is black with no battery....
First, plug the iphone into the wall with your usb cable and power adaptor. Then hold down the sleep/wake button (button on top left) and the home button (bottom middle button). Keep holding those two buttons until you see the Apple logo. This should turn it back on and then charge it. If not, Genius Bar.
Mar 10, 2011 | Apple iPhone Smartphone
My iphone 2g is not charging and its not even syncing.
the place where you plug the wire might be messed up.. do a diagnosis on it with apple
Apr 27, 2010 | Apple iPhone Smartphone
IPHONE STUCK ON USB AND ITUNES SCREEN CANNOT CHARGE
It's sounds like your iPhone is stuck in recovery mode
Try this
Sep 23, 2009 | Apple iPhone 3G
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
My i-touch is chirping and only icon shows up on screen
take it to an apple store? or you can try pluging it in to ur computer.
Sep 04, 2009 | Apple iPod touch
Phone will not charge and screen keeps showing pineapple logo
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also,Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 23, 2009 | Apple iPhone Smartphone
My iphone is dead, i tried charging it for the
What you have to do is hold the power and middle button while plugging in the sync cable, it will then show the connect to itunes screen.
Mar 05, 2009 | Apple iPhone (16 GB) Smartphone
Apple iPhone Smartphone Logo
2,542 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
