Question about LG KC910 Renoir Cell Phone
Just reverted back to my old t-mobile bluetooth head set which i have now forgotten how to use can anyone refresh old memories
Audio 50 losing its memory
In the manual, I can see there is a separate entry, for the memory power, But searching why it does not have power, is and perhaps only inside the radio is a bad connection, should be done on the system self.
Feb 03, 2015 | Car Audio & Video
Is there any way to undo a REFRESH (not a restore)
A refresh is a shorthand version of re-installing your OS without you worrying about backing-up you data, system settings and off course formatting your hard drive.
So unless u create an exact system image of your system before doing a refresh, there is no way for you to revert back once it is done.
Aug 20, 2014 | Computers & Internet
How can I pair Nokia Bluetooth Headset BH-503 with Sony Ericsson Xperia X10 mobile? Please revert back soon. Thanks.
just press call button for about 7 second until led blink red and blue~ this will reset the device in BH-503 headset memory as this headset has a small memory capacity that can store just 1 device once time...
try it, (= work for usually prob of supported a2dp handset...
Aug 15, 2011 | Cell Phones
I RECENTLY PURCHASED SAMSUNG WAVE MOBILE S8500 AND ALSO NOKIA BH 505 BLUETOOTH HEAD SET. WHEN I TRIED TO PAID THE BT HEAD SET WITH THE MOBILE. THE MOBILE PHONE IS NOT RECOGNISING THE BLUETOOTH HEAD...
ya i have bought bh 505 yesterday and i am using samsung wave s8500...i have connected my phone with bh 505....its very easy...while turning on your bluetooth headset you have to press and hold for long time till a blu light appears then you turn on bluetooth in your phone and search...it will recognise and pair the device...thats alll ucan use it now...itss awesome....
Nov 10, 2010 | Samsung Bluetooth?® WEP200 Headset...
How to delete or flash entire files in the mobile and revart back
Hi
Use the computer to format the memory card.
Thanks.
Aug 03, 2010 | Nokia 5310 Cellular Phone
How do I put this bluetooth (ant Z9i)into pairing mode? please be detailed as possible...
Pairing Procedure (This is an example only and may differ from your phone, but the process will be the same.)
1. First turn the phone OFF and then back ON again to refresh its memory.
2. Bring the mobile phone to about 30cm from the Z9i Dual Microphone.
3. Find the Bluetooth menu in your mobile phone. Turn Bluetooth ON. (Check your mobile phone user guide if necessary)
4. With the Z9i OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start fl ashing. The
Z9i is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
5. Perform a Bluetooth device discovery on your mobile phone to add a new device. (It takes a few seconds to search for
and fi nd other Bluetooth devices around you).
6. When Bluetooth devices are found, the phone will display “BlueAnt Z9i”. Scroll to it and press OK to confi rm that you
want to Pair with it.
7. Enter Passkey “0000” when your phone prompts you. The phone and Z9i will now Pair.
8. An additional security setting in your phone may be needed to allow the headset and phone to connect automatically
without confi rmation each time you connect your Z9i. Generally in the options for the BlueAnt Z9i, it will be referred to as
“set as authorized”, “add to trusted devices”, ‘’allow connection’’ or similar.
9. If required for fi rst time connection, select the BlueAnt Z9i to connect with your phone. OR, Click the MFB on the Z9i,
to connect with the phone.
You can get the manual on link below. page 9 tells you how to pair.
http://myblueant.com/downloads/manuals/Z9i_manual.pdf
good luck and please rate 4 thumbs for the free answer
Mar 28, 2010 | Blueant Z9i Bluetooth Headset
I had kept a password for my memory card...i have forgotten it....how do i get it ? and i also want to lock my memory card. how can i do it?
  • Go to file manager on your mobile,
  • In the "Settings" option,
  • Choose system folders,
  • In the "System" folder there's a file called "MMCSTORE",
  • Send that to your PC using IR/Bluetooth,
  • Then open it in notepad.
  • The password you need for your memory card is in that file
Mar 01, 2010 | Nokia 6700 Classic Cell Phone
5310 mmc recovery
Sep 06, 2009 | Nokia 5310 Cellular Phone
Nokia M73 gets switched off
Hi Friend,
The problem may be because any software my got hanged or any virus may create this problem so kindly check it out.
Or you may try the below steps,
1.Switch off the mobile
2.Remove the battery,sim card and the memory card
3.Hold the Switch ON/OFF button for 20 to 30 sec's
4.Now Replace the battery and the Sim card
5.After it has Switched ON,replace the Memory Card.
Check and revert back
Thanks and revert back
Regards,
Ayyasam
Jul 14, 2009 | Nokia N73 Cellular Phone
Forgotten bluetooth passcode
The original passcode is 4 zeros: 0000. Try that.
Aug 05, 2008 | LG VX8300 Cellular Phone
LG KC910 Renoir Cell Phone Logo
26 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
