Question about Zyxel P660HW-D1 Router
Wireless Problems Zyxel P660HW-D3
I had an P660HW-D3 router, and both Wired as wireless worked fine. Due to induction in the LANcables, the router was damaged. I got a new one form my insurance company.
When I connected thsi new one I've problems with wiressless connections to my laptop. I defined a new ESSID, WPA-RSK in the router and on my laptop The first time I connected the Laptop everything went very smooth. But after the laptop went to sleep mode and came back again, I could not connect again. Only after "restore" the wireless connection, switching the router of and on several times, I managed to connect again. This is reproducable.
What canbe the case ?
  • 784 Answers
When you defined the name for Wireless connection with you new router, did you give it a new name? If this is a case then you can delete the old name in your available wireless network list in your lap top so it won't go back to the default one which is the old one, then you are all set.
Posted on Sep 07, 2009
I have a toshiba satellite laptop my router is a zyxel p660hw the laptop can connect wirelessly to the router and gets full network access but no internet connectivity i work in an office and there are...
what is the laptop's ip address when on wireless ? default gateway ? subnet mask ? when connected on wireless ?
what are these when connected to cat5 ethernet cable ?
Is the default gateway different ?
is the ip address within the network address ? 10.0.0.3 to 10.0.0.254 or 192.168.1.3 to 192.168.1.254 ?
the first three digits should the same
what is the wireless ip address is it the same as the network router or different ?
What is the dhcp leases are they conflicting with the main router and wi fi router ?
How many DHCP servers are there ?
Nov 16, 2017 | Zyxel Prestige 660HW Wireless Router...
Router cannot connect to belkin g usb adapter it worked fine yesterday and today nothing!
Make sure to install the USB adapter's driver and utility. If it's installed, you need to use the Belkin WLAN Utility to connect to the wireless network. You should be able to find the signla coming the router and you can connect to it
May 07, 2009 | Zyxel P660HW-D1 Router
ZyXEL P-660HW-D3 password change
There should be a tiny recessed 'button' (usually more of a hole) in the back of your router. This may be marked 'reset'.
To use this to reset your router, the manual for the Zyxel P660HW router advises that your power LED should be on, but not blinking.
Push the end of an opened out paperclip into the 'reset' button (hole) for 10 seconds, or until the power LED blinks. This restores your defaults. The manual I have advises that your password will be reset to 1234. If you have a manual, please check this.
Good luck ;-)
Dec 01, 2008 | Zyxel Prestige 660HW Wireless Router...
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Nov 20, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Problem
my modem and router were working well, and then my router has stopped working
Aug 16, 2008 | Zyxel P660HW-D1 Router
Zyxel p660hw wireless problem
I forgot my modem wireless password...and I can not make a connection without cable...
Jul 12, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW - Wireless Router adsl modem set up poblem
Check in network settings that the two computers have not the same IP address.
Feb 13, 2008 | Computers & Internet
Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Jan 01, 2008 | Zyxel P660HW-D1 Router
ZyXEL Wireless set up.
First many current PC models have switches to power on the wireless feature. Do you have one of those and did you power on the wireless.
Second wireless devices communicate on four different bands A, B, G, N. Some devices support multiple bands. Does your wireless router/access point (maybe a Zytel p660HW-D1 from above) support at least one of same bands as your laptop built-in or purchased wireless adapter? If you do not know post the manufacturer of the wireless router/access point, laptop if the wireless is built-in or wireless adapter if it is a separate device and I will check that for you.
Dec 26, 2007 | Zyxel P660HW-D1 Router
Zyxel p660hw
Check if you have a firewall
In your TCP/IP set it to auto detect
Dec 03, 2007 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
357 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
