Question about Kenmore 98702 Stacked Washer/Dryer
Sears stackable one peice unit. washer top load on bottom and dryer front load on top. The proble is when the washer is in the spin cycle it make a teriable load noise. Like it is grinding becase of a bearing issue. This has noise has been going on for 6 months... What may the problem be. Other wise all is well with both units. 7yr old Sear's Stackable one piece unit............Thanks for any Help..... Jim A. in Fl.
  • James Hilton
    James Hilton May 11, 2010
    Without a complete model number I dont know who made this for sears even though it's a Kenmore, many others make the stackables for them. If it's indeed made by Whirlpool, you have a bad coupler. This is just what it sounds like. If you will get me the complete model number I'll be able to tell you for sure.
    Scholar:
  • 61 Answers
Your brearings are possibly worn, when the machine is off open the door and grab a hold of the drum (metal part on the inside) lift this drum if your bearings are worn it will have some play within its housing, i.e. it will move before the inner tub does and mannually rotate it you should here the bearings rumble if so also. they wear over time. you may be able to get them replaced but check prices first as it may be cheaper to get a new one bearing changes can be labour intensive.
Posted on Sep 07, 2009
Testimonial: "Thanks for the Info.... Jim"
The water in my stackable washer and dryer wont drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Unit shimmy's across floor
Remove the two support bars from below the washer drum from the front as instructed in the installation manual
Jan 18, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Excessive spin
I had this issue when I first purchased my stackable washer.. Because it was still under warranty, I had someone check it out. Apparently when it was installed they forgot to take out the security clamp that secures the unit during delivery.. duh!!
Jul 20, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Balancing problem Frigidaire stackable front load washer/dryer
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 21, 2009 | Kenmore 98702 Stacked Washer/Dryer
My stackable washer dryer unit is moving like crazy!!
remove front panel.
u will see 3 or 4 bracket's with 2 springs attached. There should be a bolt at the top of each bracket attaching outer tub to bracket. If one is missing (which it probably is) look around in bottom of washer & locate it. All these bolts have to be very tight & this unit is bad about bolts backing out on their own.
Feb 16, 2009 | GE WSM2700D Top Load Stacked Washer /...
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Frigidaire front-load stackable washer has violent shaking cycle
The Shipping bolts need to be removed from the back of the unit?? they go thru a plastic sleeve once the bolts are out you can twist the plastic peice to remove them completely I think there are 3 of them
Jan 24, 2008 | Frigidaire GLTF1670A Front Load Washer
Disassembly
what are u trying to repair on it?
Aug 20, 2007 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 98702 Stacked Washer/Dryer Logo
224 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
