Question about Mtd Garden
Need instructions to replace main drive & transmission belts. Mower will not go forward or backwards. MTD model # 13AN601H729
  • 389 Answers
Before you go trying to replace the belts, did you shut it down the last time you used it while the transmission was in a HIGH range?
If you did, restart it, put your speed lever back in the same or higher position with the F& R shifter in neutral, let out on the clutch/brake pedal until it takes up the slack, then pull the speed lever back into lowest speed, push in the clutch/brake and put it in PARK. Shut of the engine and then restart, it should be back to normal operation now
Posted on Sep 14, 2009
Mtd yardman differential
check your drive belts, pulley's and belt tensioner... you could of gotten better help if you would of included the model #
Dec 03, 2013 | Mtd Garden
Mower will shift into forward and reverse gears but not engage. Mower will not run forward or backward.
either your drive belt has failed or your transmission has failed. make sure the drive belt is snug and not broken, do not do this while the engine is running. if the belt is good, then it is new transmission time. they cost more than a good used replacement mower.
May 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Hi i just bought a second hand MTD C4510 ride on mower yesterday, and the drive belt came off , where can i view a diagram to fit it so it can drive forward etc
u should have two drive belts .go to nearest seller of mtd ,get owners manual .u can'not push foot speed lever to quicky up & down .start to learn how to use your mower slowly .there is no gear box for forward & reverse speed. but u have forward & reverse gearbox .talk to your dealer he will explain
Dec 10, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
I replaced the rear drive belt and now I only can go forward, what did I do wrong or what can I do to check this?
your belt is not on right. MTDs use a tension system for the drive belts to control speed. You either missed a pulley or got one backwards.
Check here for diagrams.
You will need the model # for your tractor but is a good site for all kinds of mowers
Jun 11, 2010 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
MTD ride on mower, blades turn but it doesnt go forward or backwards, not sure if there is a belt missing
Sounds like the drive belt is either broken or worn out. It is under the frame and you will have to take the deck off to get to it. If you have the model number,from under the seat, go to www.precisionope.com. Look under OEM parts and you will find a part number for the belt.
Good Day.
Oct 09, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Garden Logo
417 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
