Question about Brother MFC 210C All-In-One InkJet Printer
Displays "unable to clean..."- want help with help
In checking the link http://www.hst.net/refill.faq/inside...., everyother picture was blank. I'm not that talented to figure it without english help, then, so can you add more? I'm really grateful for your time
  • 832 Answers
Go to www.hstt.net and click refill-faq then inside then mfc215 in case the following link wont be present:
http://www.hstt.net/refill-faq/inside.html
There is no explanation needed because those pics say more than a thousand words...
Posted on Dec 09, 2007
How do I remove and replace the ink absorber pad/tank on my Brother MFC - 820 CW
Have a look at http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c which is specificlly for the MFC-210c - no sure how similar the 820CW is.
It's in German but google does a reasonable translation.
After receiving a "UNABLE TO CLEAN" message, I've just cleaned the pads on my MFC-425CN (washed in cold water) and re-set the purge counter - all working fine now.
John D. - Adelaide
Nov 17, 2012 | Brother MFC 210C All-In-One InkJet Printer
Brother Model DCP-117C Printer - Display Reads 'unable to clean see troubleshooting and maintenance chapter in user's guide'
you need a new ink absorber box which you can buy from a brother service dealer near your home (see brother homepage of your country). when done so open printer:
(use google translation german)
you have to rest the eeprom parameter, too
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will switch to maintenance mode. press by help of arrow up and set : 8 - 0. press start bk-copy til PURGE 64xx appears. press the sequence of 2 -7 -6 -3 (arrow up and set). PURGE will reset to 0000. press 9 - 9 to leave maintenance.
Apr 23, 2008 | Office Equipment & Supplies
Brother MFC 640CW keeps showing cleaning error. Installed new cartridges, tried to reset machine but to no avail.
you need a brand new ink absorber which can be purchased at any service dealer (near your home: see www.brother.com and choose your country and your mfc).
see here how to open the mfc (use google to translate german):
you have to reset the eeprom. plz search fixya for error 46 or unable to clean.
Apr 13, 2008 | Office Equipment & Supplies
Brother 420cn printer
You cant clean the ink absorber box. Go see www.brother.com and choose a service partner next your home. Buy a box as a spare part.
see pics how to open printer:
(use google translation; language is german)
Search fixya for error 46 or unable to clean on how to reset the eeprom.
Apr 12, 2008 | Brother MFC 210C All-In-One InkJet Printer
Refill ink Cartridge
see link:
http://www.hstt.net/refill-faq/brother.html#LC-1000%20-%20Doku
(the lc1000 is the same as the lc51)
Refill a max of 12ml for Y/C/M and 20ml for bk.
BTW
brother has changed the inside of the carts. So plz check carefully the pics if your cart looks the same. If it looks different you should drill the hole near the upper valve (the one with the white plastic)!
Nov 20, 2007 | Brother Black Inkjet Cartridge for LC31BK...
Cleaning
The waistinktank is full and has to be changed. Buy a new one from a service partner. Dont clean the old one, cause the felt will be as stone afterwards and wont take up any ink! See link how to open printer: http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c See here how to do the resetcode procedure: http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Sep 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
Unable to print, unable to int, unable to clean
unable to clean is the error 46. You have to change the waistinktank and to reset the error code: Buy/order a new waistinktank from a service partner (see brother homepage). Open the printer (use pictures to know how to): http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c The waistinktank (ALTTINTENTANK) is the plasticcover with the white felt in it (should be gray/black now) and the two tubes (gray/white). Unplug the tubes and change it to the new one. Reassemble the printer. After power up press menu then start mono (B/W) then 4 times arrow-up: maintenance should be displayed and printer beeps with flashing buttons. Press 8 and 0 (zero). Press severaltimes (about 15-20) start mono (b/w) until purge (Nummer is about 6425) is displayed. Press 2 7 8 3. Purge is 0000. press stop. press 99. machine comes up again. thats it. BTW: YOu cant clean the waistinktank. Buy/order a new one! If you reset the purgecount without changing the waistinktank ink will flow into the machine!!!
Sep 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
