Question about RCA Universal Remote Control
My Bush DFTA1A HD top box, scan all the channels come up but some say unsupported video and no pics or sound, others have sound but no pics, can anyone help
4 Suggested Answers
  • 159 Answers
SOURCE: hd channels not showing
Your tv has a input named COMPONENT to make work this input you need three RCA conectors (RED GREEN BLUE) plus two audio RCA Conectors red and white. If you have another set that can be plug in in this input and that set (dvd recorder, in ex.) has a digital tuner then you got it, But the Magic about the decoder box is that only cost 40.00 +- dllrs and send the signal to your antenna connector or RCA analog conector. Good luck!
Posted on Apr 14, 2009
  • 8457 Answers
SOURCE: My tv works fine.However, when I watch any HD
Check the program playing menu see if in HD.
The HD should be slighly sharper images because in higher Pixels count mode.
Posted on Sep 28, 2009
SOURCE: I have a Bush DVB-T set top box with no remote how do I program i
I NEED THE DRAWING OF THE CIRCUIT BOARD OF BUSH DVB DFTA 11/A
Posted on Sep 01, 2011
I bought a vizio tv from a private consumer, i am attempting to scan for digital channels but it will only scan for analog channels, it is an older model viziovx37lhdtv
You need a special box for H D TV. The older TV's will not work on HD but analog only. Box I bought cost me about a hundred dollars. You can buy a new HD TV for two hundred.
Jun 23, 2017 | Vizio Televison & Video
No sound comes with the video intact & it is very irregular & comes after switching one channel up or down & sometimes it does not come even after that i have a sony bravia KLV EX52 32 inch LED...
Dis you take the TV to a Sony Service Repair Center,Who does Sony Warranty Work?
Most Problems related to Audio is in the SSB Board,Sometimes caused by poor Solder Connections on the Board, you might just need to replace the ssb board and that should solve the problem you are having. What is the Model Number that is Printed on Back of TV?
Jul 01, 2011 | Televison & Video
Connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Jan 27, 2010 | Televison & Video
Manual for bush dfta5a not supplied at purchase.
I have the Bush DFTA1A set top box and plugged the aerial into the back of it, then connected the 3 cables red,white & yellow also into the back of it and the other end of those cables into my DVD/TV. then follow onscreen prompts to install it. works fine.
Aug 25, 2009 | Bush DVD2038 DVD Player
May 26, 2009 | Televison & Video
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Bush 42" rear projection rp40tv sound but no pic
any help please thanks tv turns on no problem but can not see any thing on screen. code comes up cant use menu do you no the code
Dec 16, 2008 | Bush 5693D 24" TV
I have Time Warner cable. I just bought a new Sony LCD HD tv and the sound and the video are out of sync on some channels - HD and non HD I am using a HDMI cable. Any solutions that you know of?
Yes there is a simple solution. First, for some reason., Time Warner cable boxes have SERIOUS HDMI issues, including no pic, intermittent pic and sound and the one that you are having. The easy fix is to hook the TV to the cable box using the component connections instead of the HDMI. Normally I would suggest getting the cable box replaced, but I have seen customers exchange cable boxes 3 or 4 times and still have the problem or have a new problem. Use the component connections and be sure to let me know if this works. If it does, be sure to rate this solution. Thanks!
Nov 09, 2008 | Televison & Video
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
Televison & Video Logo
238 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
