Question about Durabrand DUR7 Portable DVD Player
No valid disc
When ever I try to play a dvd it says No Valid Disc. What does it mean by that and what can to do to solve it?
Ikarus
  • 10 Answers
SOURCE: No valid disc
the codes might have got switched somehow (region codes.) go to this site www.videohelp.com/dvdhacks.php follow the instructions.....I hope this helps!!!!
Posted on Jul 24, 2007
rulds2008
  • 3866 Answers
SOURCE: portable durabrand dvd wont read disc
If it is reading a burned movie from the internet make sure you set you brun software for captability mode.
If this is a orginal disk make sure its free of dust and scratches.
1. buy a lens cleaning kit from walmart or any other eletronics store.
2. Make sure the disc is free of scratches.
3. change disc's and see if it works on any others.
if these steps do not help then the laser would need to be replaced. Durabrand is a Wal mart brand i had mine for 2 years and i had to clean the lens 3 times with a cleaning kit.
Thanks
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 17, 2009
stonephoenix
  • 563 Answers
SOURCE: No valid disc message displayed. Disc is spinning.
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 04, 2009
SOURCE: Won't play disc, says there is
Your laser head assembly has gone faulty. this is very common. Either repair or replace is only option.
Posted on May 10, 2010
fieldy14
  • 456 Answers
SOURCE: my Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Posted on Jun 07, 2010
"No disc" error
This means that the lens of your dvd player is having a hard time reading the discs. It could be dirty. You need to run a disc cleaner to run into your player for like 30 seconds. It it does not solve the problem. You might need to clean the lens manually. Open the casing and unscrew the plastice plate covering the lens. Then get a q tip damped in an alcohol. Gently wipe on the lens' surface and let it dry. Return everything back and play those discs again.
Feb 13, 2010 | Daewoo DVG-8500N DVD Player
Says no valid disc to several brand new dvds.
Has to do with the differeint codes on cd
Sep 13, 2009 | Toshiba Televison & Video
Disc read error
Dear Sir,
After 2-3 years generally all optical drive lenses goes bad,so first try by cleaning lences,if it not solves your problem then try by replacing lence of your DVD Drive,if you have any problem regarding this issue leave a feedback we will glad to assist you.
have a nice day
good luck
Sep 11, 2009 | Toshiba SD-P1900 Portable DVD Player
Disc not valid messge
yo may want to try cleaning the lens and you might also try cleaning or repairing disc an/or lens
Jun 03, 2009 | kawasaki PVS32801 Portable DVD Player
No valid disc
your not using a good disc. use a regular disc and no blue rays
Mar 31, 2009 | GPX D1816 DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
Durabrand DVD player
try a cd in it if it plays the cd and not the dvd it means a faulty lazer and most likely through it away
Feb 09, 2008 | Televison & Video
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
Durabrand DUR7 Portable DVD Player Logo
65 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
