Question about Ricoh Aficio 2022 Black and White Copier
I have a Ricoh Aficio 2022 which displays a service code SC545. Anyone know what this means. Do I need a tecnician to fix? Thanks Steve
  • 143 Answers
This is a fuser overheating problem. I'd try to clean the thermistors and make sure they are touching the hot roller then use SP810 to reset the code. (clear modes, 1,0,7,hold down the clear stop key, enter COPIER SP mode,then go to SP810 and hit execute.
Posted on Sep 07, 2009
Testimonial: "Thanks will give it a go."
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Functioning problem with aficio 1033 or 2033,not sure, church cop
You must check the display for a code like SC-542 or something loke that.
Sep 17, 2009 | Ricoh Aficio 2022 Black and White Copier
I still need help on how to solve or fix my Ricoh Aficio 2022 b/w copier functional problem error code sc545.the error code doesnt allow the copier to operate any time you turn it on. thank you
You can check the following.
1. hot roller thermistor is out of position or dirty.
2. Fuser lamp is broken.
3. Thermostat is open. (Like a thermal fuse, there SHOULD be continuity)
4. Clean and scrap clean the gold pins that connect into the copier. Sometimes they get corroded or bent slightly out of shape so they don't make contact with the terminals.
Aug 03, 2009 | Ricoh Aficio 2022 Black and White Copier
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
I need help on how to disable the functional code sc545 with my dsm622 ricoh aficio 2022 copier
Thats a fuser failure code. I suspect your upper roller is bad and has loaded up the temp sensor. The sc545 is dangerous to play around with, a possible fire danger has occured and the machine has locked you out. This requires a tech to inspect and reset. Ricoh does not allow qualified/certified technicians to disseminate this information out to the customers due to the dangers involved.
Jul 28, 2009 | Ricoh Office Equipment & Supplies
Error Code of SC545
That code will not reset by powering off and on. It needs to be reset in the service mode.
Jun 16, 2009 | Ricoh Aficio AP410N Laser Printer
Ricoh Aficio SP 420dn shows SC545 error code after power outage. I'd like to know if there is a way to reset. Thanks!
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Apr 20, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
Apr 09, 2009 | Ricoh Aficio 2022 Black and White Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 2022 Black and White Copier Logo
356 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
