Question about Dell E173FP 17" LCD Monitor
The light that indicates the monitor is on or off.
When I turn on the monitor maybe about 5 seconds later it turns off, what could be the problem?
    Brigadier General:
  • 4,090 Answers
Overload sensor is cutting in to protect the TV
You have a power board or control board failure This is not DIY
Please rate our help to keep the free service online++++ Thanks for using FIXYA
Posted on Sep 07, 2009
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Mitsubishi ws55813 picture turning off
The model indicated has a self check feature.
If turned on and green power light comes on and a few seconds later goes out:
On front of set press and hold both the menu and input(device) buttons at the same time for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it for a total of 5 times.
Let me know what error code you find.
If you unplugged the set--you will have to plug it back and attempt to turn it on--unplugging set clears the error buffer.
May 16, 2012 | Televison & Video
Oil change light wont go out on a 1999 grand am
Hello Dyno.
Have you tried using this procedure to turn it off?
OIL LIFE MONITOR SYSTEM
Resetting Procedure
  1. Turn the ignition to the ON position, engine OFF.
Drivers Side I/P Fuse Block 86382201
  1. Press and release the RESET button on the drivers side I/P fuse block.
    • The CHANGE OIL indicator will start flashing.
  1. Press and hold the RESET button until an audible chime is heard and then release.
    • If the CHANGE OIL indicator comes back on, the system did not reset. Try the procedure again.
Nov 10, 2010 | 1999 Pontiac Grand Am GT
Dell E152FP monitor after startup or coming back from standby the screen will show up and 5 seconds later it disappears. I turn off the monitor and turn it back on. The image comes back again but it...
Hello
Probably the monitor. LCD monitors use electrolytic capactors which change value with heat. The power board in yours probably has 6 to 8 caps whic need replacement. Take it to a reputable repair person or check out my websit.
Thanks
Jan 07, 2010 | Dell E153FP 15" LCD Monitor
I have a problem with my monitor not coming back on after a power interruption or after a auto update and restart of the computer. I was having some small success with turning off computer and monitor and...
It could be a cable problem but more likely to be in the power saving settings on either the monitor setup or the computer. Remember when you plug in a different monitor windows knows about it and adjusts the settings to suit. It may be that windows is using the incorrect wakeup signal for that monitor. check you have the correct driver installed.
Oct 24, 2009 | Westinghouse L2046NV Monitor
Monitor turns off after 5 seconds
Maybe, your monitor is not compatible on your cpu. Or check if the series adapter from monitor is properly inserted at the back of your CPU.
May 18, 2009 | ViewSonic VA700 17" Flat Panel LCD Monitor
How do I turn off the change oil light on a 1994 corvette
1. Turn the key to “Run,” but don’t start
2. Press “ENG MET” on the Trip
the engine.
Monitor. Then, within five seconds,
press it again.
3. Within five seconds, press and hold
“GAUGES” on the Trip Monitor. The
“CHANGE OIL” light should flash.
4. Hold the “GAUGES” button until the
“CHANGE OIL” light stops flashing
and goes out. This should take about
ten seconds.
When the light goes out, the monitoirs
reset. If the monitor doesn’tr eset, turn the
ignition off, then try again.
Nov 18, 2008 | 1994 Chevrolet Corvette
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Dell E173FP 17" LCD Monitor Logo
Alun Cox
