Question about Philips PA1035 Mouse
My mouse doesn't seem to want to connect
It doesn't seem to want to connect to my comp. I hold it in front of the receiver, but it doesn't do anything. I'm following the intructions right.
note: sometimes the cursor hopes around the page by itself, when trying to connect.
    Scholar:
  • 102 Answers
Sumfan:
I assume you have a cordless mouse?, make sure you have any other mouse like ps2 connected first, uninstall (remove the cordless mouse drivers and software from your system), restart your machine and re install the software and the drivers back.
Also make sure the receiver end coming out of your computer is on a well open space (not too close to the mouse itself)
Also the receiver is farther from other wireless devices.
Hope that helped!
Posted on Dec 09, 2007
My mouse keeps on skipping clicks, I don't know why. The wireless connection seems to be in order and everything else seems fine.
Did you try changing the batteries? If so, try unplugging the mouse receiver and plugging it back in. If that doesn't do anything, how long have you used the mouse? My mouse skips clicks because of my normal use over the years. Might just be the wear and tear to the little clicker button, but try changing batteries.
Jun 22, 2011 | Dynex Wireless Optical Mouse
I have an hp wireless mouse, and it doesn´t work!! Tried everything...
Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
Hope this could help you a lot..:-) Thanks..
Dec 27, 2009 | HP Wireless Optical Mouse
The mouse will not move the arrow
batteries new? usb cvable plugged in the computer? have tou tried to connecrt the mouse to the receiver as well? there is usually a button on the mouse and the receiver to connect the 2 together, press the one on the receiver first, then the one on the mouse.
Nov 18, 2009 | GE Wireless Optical Mouse
We have a wireless keyboard and mouse and it seems that something between them and the computer is slow or off. we type and only a few letters appear..the mouse seems to be ok just kinda slow ofrom when...
Most likely you need to re-sync the device
  1. Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers. Use the following steps to resync the devices:
    NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
    1. With the receiver plugged in, press and hold the Connect button on the receiver until the activity LED flashes.
      NOTE: Some HP computers have receivers built into the front of the computer; such as TouchSmart 700 Series PCs and Digital Entertainment Centers. Look for a small connect button built into the case. If you have a TouchSmart 500 or 800 Series PC, the receiver plugs into a USB port on the underside of the case and does not have a connect button - skip this step. Figure 4: An example of a receiver c01065862.jpg 1 - Connect button and LED activity light Figure 5: Another example of a receiver c00526313.jpg 1 - Connect button 2 - Num Lock LED 3 - Alpha Lock LED 4 - Scroll Lock LED 5 - Activity LED
    2. Press and hold the recessed connect button on the underside of the keyboard until the activity light on the receiver stops flashing. When you release the button, make sure it does not stick in the depressed position.
      NOTE: If problems persist after resetting AND there is another wireless keyboard or mouse near, use these steps again, holding down the keyboard or mouse button for ten seconds. Doing so may give the keyboard or mouse a new ID number in case the other keyboard or mouse was using the same number.
    3. Press the Connect button on the receiver again until the activity light flashes.
    4. Press and hold the recessed button on the underside of the mouse until the activity light on the receiver stops flashing. Make sure the connect button does not stick in the depressed position.
  2. If your mouse and keyboard have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
Hope this helps!! Good luck!!
Sep 17, 2009 | HP Wireless Optical Mouse
MS wireless notebook optical mouse 4000
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Jan 20, 2009 | Computers & Internet
Receiver Pings and Mouse will not work.
This is probably the problem. Turn the mouse over and find the small reset button on the mouse and press it. If that doesn work press the button on the receiver and then on the mouse. Hope that fixes it. Bud
Dec 21, 2008 | Microsoft Wireless Optical Mouse USB...
Cordless mouse and keyboard wont work together
Hi, after experimenting a little i have fixed my problem and I think I might be able to help you.
First, try press the connect button on the receiver.. Hold it for 20 sec (might not be necessary).
Then, press the connect button on the mouse and hold it for 20 sec (is necessary)
Next, wait 20 sec (is necessary) then press the connect button on the receiver but do not hold
Finally, press and hold the keyboard button for 20 sec.
Sep 28, 2008 | Logitech Cordless Mouse
Microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Aug 04, 2008 | Microsoft Wireless Notebook Optical Mouse...
Laptop does not recognize wireless mouse
Most wireless mouse are not plug and play.
Try this:
May 28, 2008 | Bluetake (bt500+bt009x) Mouse
Wireless mouse issues help
This information is straight off of Logitech's help forum. To change the channel a mouse is using, simply press the connect button on the receiver and then press the connect button on the bottom of the mouse. You can check the channel status in the MouseWare Properties under the Cordless Tab. You may also try to keep the distance between systems at least 10 feet or more. Moving the mouse closer to or further away from the receiver can also improve transmission and performance. If the above fails, try pressing and holding the "Connect" button on the receiver for 10 seconds. This will reset the receiver's connection information and allow you to do a first time connection with the receiver and mouse. After holding the Connect button for 10 seconds, press the Connect button on the bottom of the mouse to synchronize it with the receiver. Good Luck.
Jun 10, 2007 | Logitech Cordless Click! Plus Mouse
Philips PA1035 Mouse Logo
194 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
