Question about Dell Vostro 1500 Notebook
Chareger of my laptop dell vostro 1500 is not working
My laptop charger is not working. there is no physical damage seen from out side of adapter. no cut on the connecting wires at any junctio n.some days back it works some time,some times not.I think some part is loose in side the charger.i want to know how adapter is opened.if possible then plz show by fig.
    President:
  • 1,884 Answers
There is nothing you can do to a charger as the technology is such. but I have seen that in such cases the problem could also be with the socket on the laptop. check that as well. if the charger is not working then buy a universal charger and use it.
Posted on Sep 07, 2009
Testimonial: "socket on the laptop is working good.i have checked by other charger.is there no provision to repair the charger sir?advise was a bit halpful."
  • Vinay Tevatia
    Vinay Tevatia Sep 08, 2009
    Satya
    No, there is no way that a charger could be repaired. It is always beyond economic repairs.
I have a dell vostro 1000 they said that the graphics card was fried. is there anyway to get it working again
You would have to replace the whole motherboard because it is an integrated graphics chip. It wouldn't be worth it at all. You are running Vista with minimal ram and a slow CPU so it's just not a good laptop. Get yourself a new computer.
May 22, 2012 | Dell Vostro 1000 1310 1400 1500 1510 1710...
Dell Vostro 1500 not switching on...
Motherboard is bad that's why the ac adapter light will turn off ,possible short ciruit on the board. you need to have a replacement for it. Call dell tech support for repair.
Jul 21, 2010 | Dell Vostro 1500 Notebook
My vostro 1500 is down.When i plug the power cord,the charger flashs and turns off(With battery or without that).I checked the charger on another vostro and it works.
Sounds like a short on the motherboard. Usually a capacitor has blown to protect the motherboard from high voltages. I'm sure you could get that motherboard repaired if you go to the right place.
Jun 09, 2010 | Dell Vostro 1500 Notebook
Will the power cord for the Dell Inspiron 1501 fit the Vostro 1500?
AC adapter for both systems belong to D-Family 65 W lead-free AC adapter So you can use the Ac adadpter Note :- The Vostro 1500 discrete version requires the 90 W AC adapter. Without it, you will receive an error message indicating the wrong AC adapter type, the CPU speed will downgrade, and the battery will not charge.
Dec 21, 2009 | Dell Inspiron 1501 Notebook
I get the following message when I try to charge the battery on my dell vostro 1500. "The AC power adapter type cannot be determined. Your system will operate slower and the battery will not charge. Please...
Hi, Sounds like the charging circuilty is starting to fail,
Check the connection from the power lead to the DC input , is it tight ?or is there a lot of play ? if so bad connection ?
if it still under warranty, get it looked at before it stops charging completey.
Lastly , is it possible to try another charger ? make sure it the correct voltage and amps. The charger could be going down.
Regards
GeWiz.
Dec 10, 2009 | Dell Vostro 1500 Notebook
The battery in my dell vostro 1500 wont charge and i have already tried a new battery twice. The laptop powers up with the AC adapter but when I check the power meter it says the battery is at 1% with an X...
Sounds like there is a disconnect between the power in and the battery, probably a broken solder joint or a fuse. Unless you are a tech, send it in for repair.
Sep 13, 2009 | Dell Vostro 1500 Notebook
Whenever i plug my charger in, a message is displayed saying the power type cannot be determined and the computer will not charge.
I had the exact same problem (Vostro 1500), the short story is the computer is dead and I'm looking at replacing the motherboard. Here's the long story: Whenever I got the error message, I'd fiddle with the connection at the back of the computer, and "reset" the power adapter (see below for my reset procedure). That worked for a while until last week--the computer refused to recognize the power adapter, and my little trick wouldn't work. I have no means for charging the battery, so now the whole system is dead in the water. I've determined the problem is not the adapter itself, as it works fine in another similar unit I own. It's definitely the computer's power port or some internal component related to it. Lo and behold, a bit of searching on the internet has revealed that this is a common flaw with Dell Inspiron 1500 series, and Vostro is a close relative of the Inspiron. I'm going out on a limb and assuming it's the "Inspiron Affliction." Anyway, every solution I've found recommends replacing the motherboard, because the power port is integrated with said board. $225-$300 is the going price. I'd just use a dock, but Vostro doesn't accomodate a dock, so that option is out :-/
Dell Power Adapter Reset: If your power adapter has an indicator light, does it refuse to glow when plugged in? To "reset" it, unplug the adapter from the wall and computer, then unplug the cord where it connects to the transformer brick. Plug it back into the brick, then plug it into the wall but not the computer. If the indicator light doesn't glow, then something is wrong with the adapter. But if the light glows, then your adapter is good. The next step is to plug it into the computer, if the indicator light stays on, you should be OK for now (although it will probably fail permanently sometime soon). On the other hand, if the indicator light flashes briefly and goes out, the problem is in the computer -- back up your files while you still have battery power! Either way, if your computer is still in warranty, I recommend extending it another two or three years, if that's an option.
Aug 25, 2009 | Dell Vostro 1500 Notebook
My dell Vistro 1500 works on battries, but not on powder. Charger is tested and is ok
Seems that the battery charging circuitry in your laptop is defective.
The laptop needs to be serviced by a qualified technician.
Jul 19, 2009 | Dell Vostro 1500 Notebook
Need to install a dell vostro 1500 LCD inverter
Are you good with a screwdriver? Here's a step by step procedure for replacing the LCD screen on a Dell 1500.
http://www.insidemylaptop.com/replace-damaged-lcd-screen-dell-vostro-1500-laptop/
Is fairly easy, but be extremely careful of the ribbon cables, they break very easily!
Good Luck!
Jun 25, 2009 | Dell Vostro 1500 Notebook
MY DELL VOSTRO 1500 PROBLEMS
The DC power jack on the laptop may be worn out and needs to be replaced. Does it begin charging if you wiggle the power jack a bit?
Jul 20, 2008 | Computers & Internet
Dell Vostro 1500 Notebook Logo
149 people viewed this question
Alun Cox
