Question about GE 24 in. GSD3620Z Built-in Dishwasher
Ge dishwasher is 12 yrs old. water doesnt drain, checked trap, its clear..
Dishwasher is 12 yrs old. water doesnt drain, checked trap, its clear..
  • 362 Answers
Check the pump and motor to see if it is working the motor might run but the pump could be to weak to move the water, and the opposite the motor could be to weak. if you hear the motor run then its a fairly simple test put a small rag in front of the intake to the pump and carefully move it close to see if the pump tries to pull it in dont let it suck it in that will cause lots of problems.
Posted on Dec 09, 2007
My GE GSD4060Dss still has standing water
Make sure ur dishwasher is level if it isn't it will not drain all the water u can adjust the little legs on the bottom of dishwasher hope this helps
Apr 09, 2013 | GE GSD4060D Full Console Dishwasher with...
I have a 4 year old GE Dishwasher model GHDA470M00BB. Now it will not drain. I checked the drain line and it is clear. I removed the line from the machine side and remainder of the water i was not able to...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that I wrote that will help you with your dishwasher not draining problem...<br /><br />Dishwasher<span style="mso-spacerun: yes"> </span>Problems - Water will not drain out<br /><a href="" target="_blank"></a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span>
Aug 25, 2010 | GE Dishwashers
GE Nautilus dishwasher doesnt drain
Water dosent drain Is there a reset button???
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
Water remains in the bottom of the dishwasher (18 months old). Disposal is clear, glass trap is clear. What should I look for?
First : if this started after a new disposal was installed then you need to check the Knock out on the disposal located inside the pipe that sticks out of the disposal where you conect your dishwasher drain hose. ((((( Common Problem )))))
Ok, moving on, your dishwasher has a independent drain pump. if you know the noise of the drain pump and you do not here it. its a good chance that its bad and you can disconect it and put a volt metert to the 2 wires and check for 110V. of coures after you have your volt meter in place and ready to go you will then put your diswasher in drain and check your meter.
Here is a breakdown of a dishwasher with a simialr model number. # 60 is the drain pump.
Jan 09, 2010 | Frigidaire PLD4555RFC Dishwasher
GE Externa Tritan XL (7 yrs old): Standing dirty water
Hello, there isnt much that you can do, there could be a number of problems. It could be a slight blockage somewhere from your drainage hoses to your pump. It could also not be spinning properly. If you want to drain the rest of the water out you will need to get your drainage hose and lay it flat on the floor to a drain, this will stop things getting smelly. You just may have to get a repair man in, I hope this helps.
Nov 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
Water won't drain out of dishwasher
outflow soloenoid stuck/ blocked, remove and clean/ replace as required
Jan 27, 2009 | GE Dishwashers
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Water doesnt drain from my blanco dishwasher at end of cycle
there are a few things you can do. First check your trap to make sure it is clear of obstructions. Next check your drain hose to make sure there are no kinks in it, or clogs. Also is it connected to a garbage disposal? If all else fails then worst case scenario is that your pump has gone out, in which case you need to schedule a repair.
Jul 19, 2008 | Dishwashers
GE Triton XL Dishwasher
It's normal for a little water not to drain. However, many times it's that the drain hose isn't looped up high enough under the sink and water is draining back from the sink or disposer drain- into the dishwasher. If there's a disposer, be sure to run it once in a while, a good time is when the dishwasher drains. The hot water and detergent keep the unit clean, and draining correctly.
Oct 24, 2017 | GE Tritonr XL GSD6260JCC Dishwasher
GE 24 in. GSD3620Z Built-in Dishwasher Logo
196 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
