Question about Motorola Mobility SLVR L7 Cellular Phone
In cellphone i accidentally delete my audio player and java application
  • 298 Answers
Check the following
http://www.Motorola-SLVR L7.com
Thanks for ranking.
Posted on Sep 07, 2009
How to install third party java apps on my SAMSUNG GT5233A mobile phone??????????????? Is it really possible??? then, how??????????????
you can only install and play java games by downloading the java games from internet directly from your mobile's default browser. you can't install java apps from memory card or pc. but please don't forget to rating my solution.
Feb 01, 2011 | Samsung Star GT-S5233 Cell Phone
Tip
SAMSUNG cellphone codes
*2767*JAVA# Java Reset and (Deletes all Java Midlets) <br /> <span> </span>*2767*MEDIA# Reset Media (Deletes All Sounds and Pics) <br /> <span> </span>*2767*WAP# Wap Reset <br /> <span> </span>*2767*CUST# Reset Custom EEPR0M <br /> <span> </span>*2767*FULL# Reset Full EEPR0M (Caution) <br /> <span> </span>For example : *2767*JAVA# would be keyed in as *2767*5282# <br /> <span> </span>Note : Not all codes will work with SGH-C100. <br /> <span> </span>1. *#06# IMEI code <br /> <span> </span>2. *#9998*4357# Help Menu <br /> <span> </span>3. *#9998*5282# Java menu (GRPS/CSD settings for JAVA server) <br /> <span> </span>4. *#9999#0# Monitor Mode <br /> <span> </span>5. *#9999# or *#9998*9999# Software Version <br /> <span> </span>6. *#8888# or *#9998*8888# Hardware Version <br /> <span> </span>7. *#9998*746# or *#9998*0746# or *#0746# Sim Infos <br /> <span> </span>8. *#9998*523# or *#9998*0523# or *#0523# Display Contrast <br /> <span> </span>9. *#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK) <br /> <span> </span>10. *#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK) <br /> <span> </span>11. *#9998*288# or *#9998*0288# or *#0288# Battery and Field Infos <br /> <span> </span>12. *#9998*377# or *#9998*0377# Error log <br /> <span> </span>13. *#9998*778# or *#9998*0778# or *#0778# Sim Service table <br /> <span> </span>14. *#9998*782# show date and alarm clock <br /> <span> </span>15. *#8999*638# show network information <br /> <span> </span>16. *#9998*5646# change operator logo at startup <br /> <span> </span>17. *#9998*76# production number <br /> <span> </span>18. *#9998*968# view melody for alarm <br /> <span> </span>19. *#9998*585# Non-Volatile Memory (NVM) <br /> <span> </span>20. *#3243948# Digital Audio Interference Off <br /> <span> </span>21. *#32436837# Digital Audio Interference On <br />
on Jan 11, 2011 | Cell Phones
Audio player
factory origens and look for the download in mobile 9 web site
May 07, 2010 | Motorola Mobility SLVR L7 Cellular Phone
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
Problem- installed java app got hidden
Reset ur Mobile.
They Will Work.
Jan 09, 2009 | Cell Phones
I accidentally deleted the certificate
try to download themes fro your mobile from zedge.net or ownskin.com you can get all new themes try to install directly or through p.c via usb or bluetooth
Oct 04, 2008 | Nokia N81
Reinstall mp3 player Motorola SLVR L7
how to reinstal mp3 player on motorola SLVR L7, it was deleted accidentally
Feb 22, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
