Teac CD-Rewritable W28E CD-RW Burner
Problem for Teac CD-Rewritable W28E CD-RW Burner
My Teac dvd/cd-rewritable w28e CD-RW, won't read any discs!
By TARock on Dec 09, 2007
I don't know what to do with it. I can't get my cd-rom to play any discs at all. Please help!!!
Comments:
Dec 10, 2007
- Thanks James,
yes, I have windows xp, microsoft windows is the os.
Dec 13, 2007
- Thanx James,
Turns out after following your directions, I've found that I need 2 replace the device...I'll have to go back in and change the rating to fix-ya!!
TARock
Same Problem
Feb 22, 2009
-   I've problem of can't read of my cd/dvd disc of my dvd player, also all disc not read of data, not open the folder. what should i do? -   Guest
May 27, 2008
-   same but it says the drivers are installed and the device is working fine but it does not play any cd
-   Guest
Best Solution
posted on Dec 09, 2007
Very Helpful)
james klgr
Rank: Guru
Rating: 87%, 238 votes
if you just installed this device you will have to go to the utility manager and make sure all the functions are turned on, do you have windows xp. what os are you using and i can give you instructions how to go this.
Comments:
Dec 10, 2007
- 1st click start then go to and click control panel, click sounds and speech, then click sounds and audio devices, then click on hardware, the first thing on the list should be your teac dvd,cd rewriter, we will get to if it aint in a minute, if it is near the bottom right there are two choices trouble shoot and properties you can trouble shoot if you like just to see if its working properly which is a good idea, then click properties. which will tell you if it is working properly anyway in the first category which is general, at the bottom it should say use this device enable if not click the blue tab and turn it on that will fix the problem but if not and it is on, click properties and see if the digital setting is on if not turn it on if so turn it off your player might not have the drivers for digital play, well click on the driver at the top right this wikll tell you the driver date and so forth if no info you dont have the drivers, and will need to either put in the disk that came with the unit or down load them from the net the E mail address should be on the warrenty info. oh if the unit name isnt first on the list back where i said before you will have to go to device manager and add the component just click add hardware.click drivere details and they should all be listed in the box if not try to up date the drivers with the click to that next one down and follow the instructions. you should get it operating with this info if not the thing is probably bad and you will need to replace it.
Was this helpful?
Yes
No
Popular Solutions for Teac CD-Rewritable W28E CD-RW
Questions and Unsolved Problems for Teac CD-Rewritable W28E CD-RW
Do you recommend Teac CD-Rewritable W28E CD-RW Burner?
Answer
Answer
I tried to play a mini DVD in my laptop and the drive does not reconize a mini DVD disk. Teac... (More)
Answer
for some unknown reason my cd/dvd rewriter burner (Matshita BD-CMB UJ-120 ATA device) will not burn... (More)
Answer
for some unknown reason my cd/dvd rewriter burner will not start (code 10 ) when i look in device... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Teac CD-Rewritable W28E CD-RW...:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
