Question about Buck IN-SINK-ERATOR HOT ONLY WATER DISPENSER- Faucet Only - F-GN1100MBLK - Matte
The water smells in my hot water dispenser
Ibought my house with the hot water dispenser previously installed. The water coming out of the dispenser has a fairly potent smell. I have drained the tank , there is no filter on the tank and the water coming out of the sink doesnt smell at all.
    Sniper:
  • 61 Answers
There usually is an anode rod in a water heater that is there to attract the lime from the water. This helps prevent lime build up in the bottom of the tank and makes it last longer. However, the downside of this is the sulfur smell that comes as a result of the anodization (chemical) process. You could remove the rod and plug the hole in the heater to eliminate the smell. You'd give up some length of service as a result.
Posted on Sep 19, 2009
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
Hot water coming out of refrigerator water dispenser
The only way hot water will come out of the dispenser is if the main house supplying the unit is tapped into the hot water line instead of the cold.
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Rotten smell coming from water dispenser
change your water filter and clean all the lines for water,you must have an algae,mold buildup in there somewhere,and possibly water got into insulation and has startes to mold
Aug 27, 2009 | Kenmore 53632 / 53634 Side by Side...
Hot plastic smell
For now I think it would be a good time for the ice maker to be unplugged from the inside wall of freezer. Sounds like the heating element under the ice maker is remaining on. Let me know if its hot under ice maker. Even so this is something we need to find now. Sea Breeze
May 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Warm water out of water dispenser
If this is a new hook-up please be sure that your water line is connected to the cold plumbing on the house and not the hot.
IF it is on the hot the fridge is cooling it down to warm.
Please let me know if this helps you.
Jan 06, 2009 | Whirlpool Refrigerators
Softener getting all over top rim of washer
i tell people to dilute it with water so it is not as thick.
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My washmachine smells horrible. My whole house it starting to smell like it. What do I do??
there is nothing in a washer to smell - just stainless steel, rubber and plastics!
check the following:
are you using liquid detergent? if so after extended use, the machine smells like drains. put on the hottest wash with no clothes and smell will go. revert to using powder.
check there is a water barrier between the drain hose and your main drain. if not, the smell of your sewer will come up thro the drain hose.
is the drain connected to a spigot off the sink trap and do you have a waste disposal unit? these stink and unless you again have a water barrier the smell will come thro the drain hose
Jul 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Ice and Water not dispensing. Light button not working
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Buck IN-SINK-ERATOR HOT ONLY WATER DISPENSER- Faucet Only - F-GN1100MBLK - Matte Logo
417 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
salaberrios
salaberrios
Level 1 Expert
Are you a Buck Home Expert? Answer questions, earn points and help others
