Question about Cell Phones
Model e250 is asking to change from offline mode to access network services
How I change my nokia E 71cell phone off line to on line?
press the on/off button and then select General, the phone will ask you if u want to change from offline mode and allow network access..i need more info to help me help u ;) good luck !
Oct 02, 2014 | Nokia E71 Smartphone
Network is unavailable
first check ur phone setting .sometimes it is in offline mode. so make it to general profile. if still the problem persists then it is the simcard slot that is having problem.so then go to services center then
Mar 03, 2012 | O2 Samsung SGH-E250 Cellular Phone
My 6720 nokia phone has gone into offline mode and can not get it back online can you please help as this is a company phone, i have tried taking sim card out, and memory card out, still does not work
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
Good luck...
Jun 22, 2011 | Nokia 6720 Classic Cell Phone
How to online the offline n73
offline means mobile network is off. you want to change means put ur sim ,then swithch on ur mobile,mobile asking "continue offline mode" you select no. now ur network is shown in display
Mar 22, 2011 | Nokia N73 Cellular Phone
My nokia e72 still stay in offline mode .....how to change it..
offline may mean that the Sim Card was not correctly placed or a fall or shock on the phone has requested you to switch to offline mode and thus you are on that mode. This can be cured by turning off the phone and removing and putting back the Sim Card. You can also just change the settings to General if you had earlier inadvetently chosed the offline mode.
just try this one!!! first you do is to click the power switch for 1 sec. then it appears: switch off,lock key pad,general,silent,etc. you will see a offline word in the screen.... just choose general profile.... and this words will appear "phone is currently in offline mode. change profile to access network?" just choose yes.. i hope it will help your problem....
please rate :)
Dec 19, 2010 | Nokia N72 Cellular Phone
I was already inserted the sim but no signaL COMING phone is showing offline mode
offline mode is a kind of profile that helps prevent your phone from connecting to any network of any kind without your permission whilst leaving the phone on. it can be used in planes and areas where GSM are not allowed.
all you have to do is to activate your general profile by
1.pressing the power button shortly
2.select the general and it should ask you if you want to change the phone's network access
3.say yes and it should work.
hope this helped you? please rate
Dec 05, 2010 | Nokia N97 mini Smartphone
How to switch nokia e71 from offline mode to online
I couldn't find the above menu items however i found an alternative: press the on/off button on your E71 and select General. The phone will then ask if you want to change from offline mode and allow network access.
Oct 08, 2009 | Nokia E71 Smartphone
6630 offline
press the side button or check the phone's user profiles, there you will need to select the phone to connect online.
you will need to set your phone to become connected
Nov 22, 2008 | Nokia 6630 Cellular Phone
Nokia n95 is saying offline
You've probably selected the "offline" mode on your phone. To get the phone to access the network again, go to the idle mode of your phone, then press the power switch of your phone ONCE, then select any profile.
Ex: meeting
It'll then display a message like " phone is currently in offline mod. Change profile to access network?"
Select "yes"
That should fix your problem
Let me know how it goes.
johnny
Sep 16, 2008 | Nokia N95 Cellular Phone
N70 Battery Issue
Even when you run the mobile in offline mode you might use it for listening to songs or any other applications..So please check if the battery life stands for around two days to around when you choose the network selection..If not then better take you moobile to any Nokia service centre..!..
Aug 11, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
73 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
