GETTING LINES ACROSS PAGE WHEN PRINTING
I CHANGED TO NEW CARTRIDGE BUT GETTING LINES ACROSS PAGE WHEN PRINTING. I CLEANED THE MACHINE AND DID ALL THE SHAKING OF THE CARTRIDGE ETC
SOURCE: printing blank pages
My printer has funn ink cartridges and it is printing blank pages and it is saying that the ink is empty. Please help
Posted on Oct 01, 2007
  • 1003 Answers
SOURCE: Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Posted on Jan 15, 2008
  • 96 Answers
SOURCE: Kodak EASYSHARE 5500 will not print with black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Posted on Aug 19, 2008
57 varieties
  • 1653 Answers
SOURCE: Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Posted on Sep 26, 2009
sayer268
  • 147 Answers
SOURCE: When I copy there are black lines across the page.
Lift the copy bed cover and locate the **** glass (it is about 1" wide and sits on the left of the large glass)
Use a microfiber cloth, and a bit of water, and remove the debris from this **** glass. Make sure it is clean, then clean the white bar on the underside of the top cover (It will sit on that **** glass)
take a blank piece of paper and copy it through the feeder, if you have lines on the page that prints, you need to look harder for a spec on that glass. a small dot will create a line on any document fed through the feeder. A dot on the large glass will print only the dot as the paper is not moving over it.
Posted on Jan 13, 2011
Testimonial: "Thank you!"
We are getting a double printing and toner residue on each page as we print. We have changed out the toner & cleaned the machine. What next?
if replacing the toner cartridge didn't work, then the fusing unit is probably broken or not getting enough power. replace the fuser.
Sep 27, 2010 | HP LaserJet 2420 Printer
Awfull printing!
Actually, you are correct.
This is a drum issue. Perhaps the drum needs to be cleaned (A soft cotton cloth may help). If the lines are vertical, it's possible that the drum was scratched and may need replacement.
Oct 10, 2009 | HP LaserJet 1012 Printer
Hp 7310 printing with color horizontal streaks across. parts of the artwork are fine, then strirated lines down whole page. changed cartridge color and b/w and says it's installed fine. test page is...
usually when there is a defect on printing out while you have changed the cartridges , you will need to consider changing the printheads of that printer.
Aug 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
How can I do a test print and adjust on HP C4180? I can't find the screen that allows you to adjust alignment etc.I am getting lines across my pictures. thanks Malkbk
Lines across the picture is usually dirty, or soon to be empty cartridge. But here is how you get to HP Tool Box:
START->SETTINGS->PRINTERS & FAXES->RIGHT CLICK ON PROPERTIES->BOTTOM PRINTING PREFERENCE->SERVICE TAB > and you have the place where the tools are kept.
You probably saw the print a test page next to the printing preferences...there you have it.
good luck , please leave rating. thankyou
May 06, 2009 | HP Photosmart 4180 All-in-One Printer
Spaces in printed lines
then the problem is in cartridge replace them asap, no other way around it,
cheers
Sep 04, 2008 | Dell 922 All-In-One InkJet Printer
Lines printing every time I copy
Look at the image drum (at the bottom of the toner cartridge)
Jun 10, 2008 | HP LaserJet 3330 All-In-One Printer
HP Laserjet 1200 not printing in one area
your fuser is truly unhappy..time for a new fuser
May 28, 2008 | HP LaserJet 1200 Printer
Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
110 people viewed this question
jasbo
jasbo
