Question about LG Televison & Video
I NEED INSTRUCTIONS TO REPLACETHE LAMP IN MY LG
I NEED INSTRUCTIONS TO REPLACE THE LAMP IN MY LG DLP REAR PROJECTOR TV MODEL NO,DT62SZ71DB WHERE CAN I DOWNLOAD A MANUAL FROM, TKU VIXIN
  • jpsaturn1 Sep 07, 2009
    thank you most sincerilly for your extremelly helpfull and prompt reply even I can follow this and I'm a half blind techno illiterate 60 yr old woman. thank you again.....from saturn1.
    President:
  • 632 Answers
Note: Wear cotton gloves when handling the lamps as it contains mercury.
  1. Remove the access cover behind the On/Off switch at the bottom of the rear cover by removing the 2 screws using a Philip screwdriver.
  2. Behind the cover is a metal box with a handle that protects the rear of the lamp. Remove the securing screws and pull the box with the handle.
  3. Remove the cable screws and pull out the plug.
  4. Remove the lamp clamp screws and lift the lamp
  5. Put the new lamp in place of the old lamp in reverse sequence of the above.
  6. Dispose the old lamp properly.
  7. Reset the lamp timer.
  • Make sure the TV is on.
  • Press and hold Menu button on the TV set.
  • Press and hold Menu button on the remote control at the same time
  • Hold the buttons until the service Menu pops up.
  • Release the Menu button on the remote then on the TV set.
  • Press and hold Enter /Ok on the TV set then press and hold Mute button on the remote control.
  • Hold the buttons until the Lamp Life Hours screen pops up.
  • Release Mute button on remote then release Enter/Ok on the TV set.
  • Press Select twice to confirm the reset of the counter.
Posted on Sep 07, 2009
LG DLP TV won't turn on
Your lamp has probably failed. You can buy a new bulb for under $100. http://projectorlamps.com/lg-zenith-dlp-tv-lamp-ru52sz51d-bulb.html RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG Televison & Video
Buzz sound from Toshiba model 72HM195
Mine is doing the same thing. I think its the cooling fan. The bearing is probably gone.
Nov 22, 2012 | Toshiba 72HM195 72-Inch Diagonal...
On screen message "lamp life over, error!!, which
Hello John:
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the counter...otherwise you may get an annoying reminder every few days if you're surpassed the predetermined hour mark.
To Reset:
Ensure the TV is powered on.
1) Press and HOLD the MENU button on the TV
2) Press and HOLD the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
3) Let go of the REMOTE button first, then release the button on the TV
4) Press and HOLD the ENTER (or OK) button on the TV
5) Press and HOLD the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
6) Let go of the REMOTE button first, then release the button on the TV
We suggest writing your lamp hours on a piece of masking tape and taping it to the back the TV for future reference.
7) To reset the lamp counter, press SELECT (or the button in the middle of the direction arrow buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly...
Mar 22, 2011 | LG Televison & Video
Replaced lamp How do I get rid message on tv screen Replace lamp
You need to go into the TV menu to the service section or lamp hours section & look for a statement like "RESET LAMP HOURS" or similar. Once you complete the task the message will no longer show. If you can't find it you can email me at PRMHELP@EARTHLINK.NET with your Make & Model # of your TV & I can give you specific instructions. I specialize in DLP & LCD Projector repair but projection TVs use similar hardware.
Good Luck,
Jim
Oct 02, 2010 | Sony Televison & Video
My rca dlp doesn't turn on
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
What the model lamp for projector thomson 50dsz644
www.myprojectorlamps.com/rptvprojector/THOMSON/50%20DSZ%20644.html - United States
www.chooselamps.co.uk/search/projector-lamps/make/THOMSON - www.soundandvisionav.co.uk/.../THOMSON-50DSZ644--DLP-TV-UHP-Lamp-.html -
There are some links above.
Mar 24, 2010 | Thomson 50DSZ644 50" DLP Rear Projection...
I have changed out the bulb in my LG dt62sz71db rear projection, but it still doesn't start. the bulb lights for a second then back off again. can you help with a solution?
wine you trun it on do you hear eny noise
comeing from the back of lamp.you should hear the lamp balstor a biz nose if you don,t the lamp power supply need to check.
Aug 19, 2009 | Televison & Video
Projector went out
I assume you mean replace the dlp lamp inside a rear projection television. You didn't give a model or TV brand, so I can't point you to a direct lamp model to buy. Best I can do is say, go to http://www.dlplamps.com and see if they have what you need there.
Feb 16, 2009 | Sony KP-51WS500 51" Rear Projection...
Set lamp timer
Jerico, If you will go on dlp lamps .com I believe they answer that question in their FAQ. You can also give them a call. Look on their site for number. All I know is that they make the whole process really easy.
Jul 11, 2008 | Panasonic TY-LA1000 Projector Lamp for...
TV won't come on
the power pack of the tv is faulty.check the power pack.it is devided into the standby mode and the main power mode;an ic (POWER IC ) IS RESPONSIBLE IN THE POWER PACK .
Dec 23, 2007 | LG DLP Projector 1400Lum RD-JT30...
Televison & Video Logo
Computer Repairing
Computer Repairing
