Question about Durabrand Audio Players & Recorders
My Durabrand CR 210 clock radio Beeps
My Durabrand CR 210 clock radio "Beeps" a series of 5 beeps about every 5 minutes, starting about 10:00 PM, lasting for 20 to 30 minutes. Alarm function is off. Why is it beeping? It just started this about 3 or 4 nights ago.
SOURCE: My clock beeps every hour
If you hold down the Alarm/Select button then press the Mode button you will see that all the arrows pointing to the MTWTFSS will go away if you press the Mode button again. When the arrows turn off the hourly chime goes away.
Posted on Oct 23, 2007
SOURCE: Hourly beep
click alarm set button the off/reset button should see "00" icon on screen go off or on
Posted on Dec 13, 2007
SOURCE: clock radio frozen in time
I have it too, and I think it has something to do with the timezone, so try resetting your timezone, and then the clock. it was happening to me, and I fixed it somehow. hope that helps.
Posted on Jan 03, 2008
  • 12 Answers
SOURCE: HP dx5150 Microtower PC won't start up just beeps
That's what's called a POST beep code. The HP DX5150 beep code info can be found at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=447468&prodTypeId=12454&objectID=c00868914,
but for your benefit: 5 beeps means you have a memory problem. Take out the DIMMS (memory sticks) and reseat them. Try to boot. If you get the POST code again, you have bad memory (unlikely, but could also be a bad FSB on the motherboard). If you have more than one memory stick, remove one, try to boot, if you get the error, put it to the other memory slot, try to boot...then do the same procedure with the other stick. If you can get it to boot on one stick, you know the other is bad.
Posted on Mar 14, 2009
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
Where do I return a Durabrand AM/FM clock radio?
when in doubt check their website . no doubt you need to have a return authorization form from them .
Jun 11, 2015 | Durabrand Cr-502 Clock Radio Personal...
How do I unlock the CLS 1410 series?
press the menu button for 3-5 seconds until it beeps. Release as soon as it beeps or you may lock it again. You can program even when it is in lock mode.
May 14, 2015 | Motorola Radio Communications
Hi,Ive been trying to set my icf-cd2000 clock radio,I downloaded info,It is so small I cant read it.(ive tried to make it larger on photo copier) but it only blurs ,can I buy a manual please,Or do you have...
Setting the Local Time
  1. Press WORLD/LOCAL to display "LOCAL".
  2. Hold downl CLOCK until you hear a beep.
  3. Press TUNE/SCAN TIME SET + or - to set the hour.
  4. Press CLOCK to enter the hour.
  5. Press TUNE/SCAN TIME SET + or - to set the minute, and then press CLOCK. Two beeps sound to confirm the setting.
Setting the WORLD Time
  1. Press WORLD/LOCAL to display "WORLD".
  3. Press TUNE/SCAN TIME SET + or - to set the desired hour and press CLOCK. Two beeps sound to confirm the setting.
If you need any more help, feel free to ask.
Mar 08, 2011 | Sony ICF-CD2000 Clock Radio
How do you set the time? I figured out the alarm clock but can't find a way to set up the time.
Setting the Clock
1. Press and hold the HOUR button for 5 seconds (Fig. 5). The time will begin to flash
2. While the time is flashing, press the HOUR button until you reach the correct hour. Then press the
MINUTE button (Fig. 5) until you reach the correct minute.
NOTE: PM indicator will appear on the left side of the clock face for evening hours (Fig. 5). If the
PM indicator is not illuminated, the hour is set to AM. Be sure to set the time for the correct
12-hour period - AM (morning) or PM (evening).
NOTE: After 5 seconds, the time will stop flashing and it will be set.
Mar 03, 2011 | Homedics SS-4000 Clock Radio
How do you set the clock
Clock setting procedure is written in user manual, click Sony Support to download a copy.
Plug unit in AC, display will flashing AM 12:00
Cress clock button for few seconds, unit will beeps and hours will start flashing.
Press tuner/track+time set +/- button to change hours, again press clock button to change minutes etc.
Hope this info will help you.
Nov 24, 2009 | Sony ICF-CD543RM Clock Radio
Sony radio/cd/clock under the cabinet. Lost
On the right side there is a push button switch labeled "Clock". It is springloaded so you have to push it in and hold it for a couple of seconds until the unit beeps and the hour position starts to blink. The volumn up and down buttons will control the changing of the numbers up and down and PM/AM. Pushing the clock button again will change the clock to the minutes position and you cann adjust the numbers up or down just like the hours. Push it one more time will lock-in the new time. Your done.
Jul 20, 2009 | Sony UNDER-CABINET LCD-TV DVD/CD CLOCK...
I have a 1997 bmw 328i Convertible 3 beeps coming from dash board
check your clock next time you hear the beeps...chances are it is at the top of the hour!
Apr 25, 2009 | Car Audio & Video
My clock AJ 3010 clock radio gives off an electronic sound every 10 to 20 minutes. It's like a warning sound you get from a smoke alarm when a battery is running low. I've tried replacing the batteries but...
If you want to turn off all system beeps (like the ones that go through your computers' internal speaker ):
  1. Go to Start-->Run-->Type Regedit.
  2. Go to HKEY_CURRENT_USER\Control Panel\Sound
  3. Edit the key Beep and give it a value of No
This will help you to turn off system beeps.
Apr 20, 2009 | Philips AJ3010 Clock Radio
Unable to set the alarm
To Set the alarm time: Press and hold the ALARM button down, and then press the hour/minute buttons to obtain desired time (Note the PM indicator on the screen for PM times)
To Enable the alarm: Move the sliding switch to AUTO or ALARM (Auto is for radio wake and Alarm is for beeping noise) *remember to turn up the volume knob if using AUTO (radio) setting.
Dec 04, 2008 | Lenoxx Electronics Clock Radio With CD...
139 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
