Question about Sony Ericsson K510i Cellular Phone
The screen is all white
The phone is fully functional, just nothing on the display. It did this to me a few times but came back after I gave it a good shake. The display also started scrolling before it went blank.
  • 298 Answers
You need to re-seat replace the ribbon cable that is connecting screen to main board. Possibly out place after unit was dropped.
Posted on Sep 07, 2009
    Problem Solver:
  • 11 Answers
The push fit / auto fit connector connecting ur dislay ribbon cable to the main pcb has become loose or the self locking mechanism of the connector has become unserviceable. u need to fix the ribbon cable permanently to the connector on the main PCB
Posted on Sep 09, 2009
Dell M2300 issues: After several times of a freezed screen & rebooted the computer while either on the internet or working with "Autocad Inventor", it's finally gave up on me, on the last...
Isolate where the problem is: it could be the LCD display or the graphics circuit on the main board. Connect the VGA output of the laptop to an external monitor - one that you know is good. From the function keys, activate the VGA output of the laptop - it's suppose to switch between the LCD display or to the external monitor. Switch it to the external monitor. If the external monitor works, then you have a problem with the LCD display of the laptop.
Dec 22, 2010 | Dell Precision M2300 Computer Workstation ...
How do you fix blank screens?my internal is half white,abd external is fully white
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Nov 28, 2010 | LG enV3 VX9200 Cell Phone
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
When i turn on my mobile n70 after it give me white screeen
Hello there,
You can to do a FULL format, do the following:
1. Make sure your phone is fully charged to handle the formatting process.
3. Turn off your n70.
4. Press and hold the following keys at the same time:
a. Green dial key
b. * or the star key.
c. the no. 3 key
5. Press the power on to switch on the phone. Take note: Hold those keys until you see a formatting word on your screen.
6. Wait for a few minutes until formatting is completed.
Hope this helps you. Good luck!
Dec 08, 2009 | Nokia Cell Phones
Only white light appears nothing else appears.
hi
first try to connect to a pc using the usb and check if u can get connected and browseif this works then there is a problem with the display else the OS of the phone is lost
beware that all your data will be lost on the phone if the following procedure is followed
hold the green button '3' button and the '*' button simultaniously and then power on the device hold the keys till 'FORMATTING' is displayed on the screen
hope this helps
Cheers
Jun 17, 2009 | Nokia 3230
Hello -need help with phone
Hi Nick,
There are no intensity adjustments I know of, and from my experience if the backlight is still working, but you get no display, it is either a bad display, or many times corrosion or a broken solder joint/component. I wish I could help you correct the problem with a few pushes of a button but not in this case. We do fix those models, you can check us out at www.cordlessrepair.com Thanks, CG
Nov 06, 2008 | Panasonic KX-TG2357 Cordless Phone
Problem with display of Nokia 6600 mobile
my nokia6600 occurs same problem
when i switch off and then switch on the phone then display comes for the time i am using the phone. As i left the phone for sometime without pressing any key it again goes to that white screen mode..but phone is functioning .plz help me to rectify the problem.....
Jul 14, 2008 | Nokia 6600
Sony ericsson w850i blank screen
I am having the same problem with my w850i, poweres up but nothing more than a blank screen? Any suggestions?
Jan 20, 2008 | Sony Ericsson W850i Cellular Phone
White Screen No Work
have the LCD/screen replace...take it to a mobile tech and have that done.
Dec 26, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Sony Ericsson K510i Cellular Phone Logo
138 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
