Question about HP iPAQ HX2415 Pocket PC
I'm running Vista and I'm having trouble with my HX2415.I have Windows Mobile Device Center Installed. When I plug the unit into a USB port it doesn't find the hardware. It worked fine on XP with Active Sync 4.5 What's going on?
  • 2 more comments
  • Jerry Ram Sep 07, 2009
    I have V 6.1 32 bit version running on Vista Ultimate SP2 32 bit. When I start Windows Mobile, it says Not Connected. I have tried different device settings, but nothing works. Also tried different USB ports. No Luck. Need more help.
  • Jerry Ram Sep 08, 2009
    I synced with Bluetooth and installed the Firmware. How do I know it is installed. Windows Mobile Device still doesn't sync.
    Thanks for sending me the link, however, I don't see where it says that the HX2415 is incompatible with Vista. Perhaps I'm overlooking something?
  • Jerry Ram Sep 09, 2009
    I've been trying to install the HX 2415 Firmware update package, but I keep getting the notice saying " The Update was not valid. The Update files will be deleted. The update is a direct DL from HP it is the file Sp32878.exe I can only connect to my PDA with Bluetooth Activesync. I'm running Vista and Wm5 and WMDC 6.I've been told that I won't be able to run ActiveSync via USB until I installed this FW update.
  • 11,896 Answers
Make sure the latest driver is downloaded and installed. Then make sure program and device is allowed through firewall. THen make sure device is turned on before hooking up via USB.
Posted on Sep 09, 2009
  • 1 more comment
  • Nate Stansfield
    Nate Stansfield Sep 10, 2009
    Make the drivers are specifically for vista. Don't download ones for xp or whatever else. Then after downloaded, you must double-click ton install them. Then after they are installed, reset computer.
  • Nate Stansfield
    Make sure on the device file under my computer, find the drive, right click, go to properties. Make sure that read or write only is NOT checked.
  • Nate Stansfield
    Nate Stansfield Oct 01, 2009
    You can also download a program called unknown device installer and if wanted, a program called unknown device driver
  • HP Master
  • 497 Answers
IPAQ HX2415 is not compatible with the Vista Operating System, check the link for detail information:
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=iPAQ%20hx2415%20128MB%20WNICb%203.5%22TFT%20Pocket%20PC%202003&v=HP&uid=FA299AABA&pf=0&pi=2&c=Communications%20Devices&sc=PDAs&os=32-bit
Please provide mode details like error message so that I can find the exact solution or any third party application to make it compatible with Vista Operating System.
Posted on Sep 08, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. HP ipaq HX2415 is compatible with Windows Vista Mobile Device center Version 6.1. Please check if you are using version 6.1, you can download the Windows Vista Mobile Device center Version 6.1 from this link--
Windows Vista Mobile Device center Version 6.1 Link
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 07, 2009
  • Rylee Smith
    Rylee Smith Sep 07, 2009
    Hi
    You'll need to upgrade your ROM/firmware so that you'll be able to connect it with windows Vista. Kindly note that firmware upgrade will delete all the user files and contacts saved in your ipaq device memory. So, backup all the data and other contacts info by syncronizing it with another computer(which is using windows xp) or copy all the content in the memory card of your ipaq.
    Thanks
    Rylee
  • Rylee Smith
    Hi
    You can download and install tghe firmware for your ipaq from this link--
    HP iPaq HX2415 Firmware
    Thanks
    Rylee
I cannot access windows vista to sync with my hp 6310 ipaq
Greetings - I'm going to guess that perhaps you installed Activesync 4.5, For Vista or Windows 7 you have to install Windows Mobile Device Center which is available HERE.
If you are using mobile device center that isn't the problem and Microsoft has a dedicated section of their website dedicated to solutions syncing Windows Mobile device with Vista, way too much for me to go over here. There's a great deal of trouble shooting information about sync problems HERE.
Thanks for using Fix Ya
Mikeywaf
Mar 16, 2011 | HP iPAQ H6310
Syncing my MobilePro 790 with my computer
yes...quite an issue, eh? what is the actual model and make of that device?
Mar 20, 2008 | NEC MobilePro 790 Pocket PC
How do I transfer files or applications from pc to the htc snap?
You need to install on your computer ActiveSync/Windows Mobile Device Center. To install this, insert the "Getting Started" CD into your computer and follow the setup steps. If you don't have the CD anymore, you can download the ActiveSync from this link.
Once ActiveSync/Windows Mobile Device Center is installed you connect the HTC Snap to your PC using the USB cable supplied with your HTC Snap, then you will be presented a configuration Wizard that will take you through the set up process.
You can connect the device to your computer using USB either as an External Drive or through Microsoft ActiveSync. If using Windows Vista, you will use Windows Mobile Device Center (WMDC) rather than ActiveSync. Simply plug the device in and choose an option on the screen of the device.
If you will use it as an External Device, you can copy data on it as you would copy on a USB flash drive, with copy and paste.
Another option is to use the bluetooth to transfer files, if you have a notebook which has bluetooth capabilities or you have a dongle.
Dec 20, 2010 | HTC Snap S521 Cell Phone
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
I am running Windows 7 on my Laptop. How do I
Download windows Mobile device center, then connect your mobile phone to the computer using the USB cable, Under Mobile Device settings click on connection settings.
Download Windows Mobile Device center from http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/device-center-download.mspx
Apr 11, 2010 | HTC S710 Smartphone
I LOST MY DRIVERS CD FOR HTC P3400 I
i have lost my p3400 htc driver cd where can i down load it for free and which site can y please help me
Aug 15, 2009 | HTC 2in1 USB Cable 4 MteoR S630 S710...
Need driver for vista to sync my acer n35
Acer N35 is running on Windows Mobile 2003. You can use Windows Mobile Device Center 6.1 for windows Vista to sync your PDA to your computer. You can Download Windows mobile device center 6.1 on this link :
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center.mspx
After installing, plug in the Acer N35 PDA and Windows Mobile Center will; automatically start and you can transfer files and sync contacts etc.
Oct 27, 2008 | Computers & Internet
Windows Mobile Device Center (Vista SP1 32bit) Can't sync with my IPAQ HX2490b
For the Samsung i760, disable "advanced network functionality" in the "USB to PC" setting by uncheckmarking it. Then Vista and WMDC will detect the i760 properly...
Apr 01, 2008 | HP iPAQ HX2490 Pocket PC
Win Mobile Device 6.1 Vista will not Connect
Slmgato: have you tried to delete the old pairing on wmdc?
also to the other users: check the usb charge port on the tilt. Make sure it has not been bent or the pins have not been damaged. My tilt recently was damaged and now i can't charge or sync, but i can buy the replacement port for about 10 bucks and solder it myself.
Mar 18, 2008 | AT&T 8925 Tilt Smartphone
HTC PPC-6800 Vista driver and/or WMDC install problem
hey u need to install windows mobile device center first, not its update, on ur vista, as activesync cannot be installed on vista...
download it from
http://www.microsoft.com/windowsmobile/devicecenter.mspx after a validation check..
Jan 26, 2008 | HTC PPC-6800 Smartphone
HP iPAQ HX2415 Pocket PC Logo
148 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
