How we have take counter reading from the printer
  • helpdesk_mum Sep 07, 2009
    i can't take uservise details of printed page in xerox phaser4510n printer.
  • Nandini Dhar
    Nandini Dhar May 11, 2010
    Sir, which model no.
How do I get a meter reading on a Savin C4540 Copier?
On display panel press'user tools' look at display find 'counter' press counter .
Sep 11, 2015 | Savin C4540 C3535 Fuser Unit B2234021 -...
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
T630 clear counter
The following will reset the maintenance count after you install the maintenance kit, you can not reset the printer total page count. Press and hold down the [Select] and [Return] keys while powering on the printer, hold these buttons until the display reads "Performing Self Test." If the display readds "80 Schedules Maintenance", press the [Go] to continue past this message and access the Configuration Menu. Press the menu button until the display reads "Reset Maint Cnt" on the second line of the display and press the [Select] button. The top line of the display should now read "Reset Maint Cnt" and the second line will read "Reset" and press the [Select] button. This will reset the counter. To exit out of the "Configuration Mode" cycle the power.
Apr 15, 2013 | Lexmark T630 Laser Printer
Show that ink is finished , but it's not .
Printer "read" ink level counter, not ink level actually. Refillable ink tank read as empty ink. Two methods to resolve this. Reset ink level counter using software. Or disable ink level counter reading.
Jan 26, 2013 | Canon PIXMA MP495 InkJet Printer
My epson r 230 printer is showing 'service required parts inside the printer are at the end of their service life' please find the solution
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
May 20, 2010 | Epson STYLUS R230 InkJet Photo Printer
How to fix epsonTX110 printer if the warning says the ink pads are at the end of their service life
May 12, 2010 | Epson Stylus C46 InkJet Printer
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Myprint totals say zero.
Press the counter check button. What counters do you see. There can be up to 6 different ones I believe. What counter numbers do you see e.g. 101: Total 1
Counters to display can be set using Service Mode. Press Additional Functions > 2,8 > Additional Functions.
Copier > Option > User > COUNTER1,COUNTER2,COUNTER3,COUNTER4,COUNTER5,COUNTER6
Default's are COUNTER1: 101, COUNTER2: 103, COUNTER3: 201, COUNTER4: 203. COUNTER5, COUNTER6 none.
You could try entering those counters.
The counters could have been reset. It is apparently possible but certainly not advisable to do so without permission from Canon.
Jul 13, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
71 people viewed this question
jasbo
jasbo
