Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Logitech Laser Mouse not working properly
The mouse will still scroll on the screen and the right and left clicks are working. I do not see any sort of laser coming out of the bottom of the mouse. I am thinking maybe the laser itself is broken and everything else is fine -- obviously it is still connecting or I wouldn't be able to scroll or click...
Do you think I just may have to just go buy a new one?
  • 1,555 Answers
Nothing to worry Just your LED has given way due to long usage. It seems you never switch off your UPS or power supply properly because you can monitor for yourself even after shutting down your red laser on the mouse will keep on glowing until you switch off the power supply to CPU. You can use your mouse without that LED also.
Posted on Sep 07, 2009
2 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: How do you open Logitech laser cordless mouse to replace batteries?
puhs open the logo area (palm area), toward the backend. it takes 2 aaa battery.
Posted on Nov 06, 2008
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
The left click button on my Logitech M555b mouse stopped working earlier today for no apparent reason. It has no physical damage, such as dents, scrapes, or water damage. The mouse is only about 2 months...
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Or disconnect the mouse from your computer restart.
If still does not work you need a new mouse.
hope this helps
Sep 30, 2012 | Logitech Mouse Bluetooth M555b Black Pc...
I have a logitech laser mouse, with vista, how do I change the settings for the mouse
Start > Control Panel > Hardware and Sound > Devices and Printers > Right click on mouse icon and click Properties
Mar 02, 2011 | Logitech Cordless Mouse
Logitech V450 Nano Cordless Mouse Left & Right Click Problems
I have the same problem.. Is that you have sims 3 installed?
Oct 24, 2009 | Logitech V450 Nano Cordless Laser Mouse
Laser mouse scrolls off screen
try the mouse without any logitech software installed for it if it keeps scrolling out of control check your mouse settings in control panel. go scroll and select the scroll to lines 5 or less. see if that changes anything.
Jul 14, 2009 | Logitech MX1000 Laser Cordless...
My Logitech LX5 wireless optical mouse has never worked properly
hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
Logitech mouse installed, set left/right incorrectly
If you still have the disk for it you can reinstall the driver by going to the Control Panel > Printer and Other Hardware > Mouse > Hardware (Tab) > (Select Your Mouse) > Properties > Driver(Tab) > Uninstall. After uninstalling put the disk and install the driver.
Aug 08, 2008 | Logitech Computers & Internet
Microsoft wireless laser mouse 5000
Assign a keystroke to the mouse, in this instance I assigned 'p' for pan (as per the .pgp file short cuts etc) against the scroll wheel click.
Click the scroll wheel, 'p' comes up on the cad screen, right click to confirm then the pan icon appears, hold the left mouse button and drag at your leisure. Yet to find a fix for Inventor.
Not ideal, but better than nothing at presnt.
Jun 08, 2008 | Microsoft Wireless Laser Mouse 5000
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
241 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
