Question about Toshiba 36A50 36" TV
A thunderstorm blew out my 36 toshiba and the power light comes on but nothing else, is this repairable? Thanks
  • Toshiba Master
  • 8,457 Answers
Yes,not more than $150 dollars ok,not worth repairing CRT tube tv more than that.Take to the shop get the estemate.
Posted on Sep 07, 2009
What's the most likely problem with my 50" LG 50LN5100 LED LCD TV. The standby light illuminates when plugged-in but the screen doesn't come on nor is there any sound when the TV is turned on.
Thunderstorm over the coax or /and the power supply measure the power supply by a defect cannot be measured anymore over an analog hand adjustable power Variac transformer from 0 to 240 volt. because a protection can be given by a defect t-con board (as suggestion) but the variac its good to bypass/ overhaul the build-in safety protection circuit inside the power supply board then sometime if there else are broken or bad components hard to find they can be sometimes intentional burning out or become warmer by twist the variac power slowly up from of zero volt until the max necessary voltage T-con boards that can have a problem with smd components sometimes they can burning out the defects but its only to do if there is no equipment to measure repair or nothing was to find without a service manual or other optical defects , an short-circuit tuner also by thunderstorm sometimes only the little ceramic capacitors what hangs to earth (chassis) if the thunder energy was coming over the antenna coax cable. the power supply can stand in a safe protection mode. then a refurbished board somewhere can be necessary that will give a reset to release the protection mode in the power supply.. Thunderstorm can be strange and much different and i have had 2 times repairing when there was only 1 ceramic short-circuit ceramic capacitor to find thats was with one leg is( on cold-earth) on the chassis. as the one and only defect component. A time in a TV and 1 time in a radio , sometimes its realy strange but comes it over the power supply its hard to find because of more recurring complaints if partial repair in smd circuits. hard to do without necessary tools.
Jul 26, 2017 | LG Televison & Video
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Toshiba TV dead: is there a fuse inside? Toshiba 24AF46 is dead after a thunderstorm and nearby lightning. Plug sparks when I plug it into the wall. Nothing happens on the TV. No sound, nothing when I hit...
Yes,there is a fuse in inside on the tv main pcb board near the power a/c cord.But if the tv have sparks,main pcb board could have more other components fries too.If tv less 10 years repair it by a shop,more than that should buy a another tv.
Jun 09, 2011 | Toshiba 24AF46 24" TV
Power light blinks - and now the TV won't come on
Most likely the power supply and/or related circuitry has failed.
Charlie
Aug 23, 2009 | Philips Magnavox 27MS343S 27" TV
36" toshiba suddenly turns off and the little red light flashes
Some el.components are loose on tv circuit board.I have removed the back cover,supported tv picture tube 45 deg.against wall.This tv is heavy!One screw on left holds the circuit board to bottom case.Removed and supported this board on few heavy books.Turned tv on and gently probed all the componets on top of the board with plastic drinking straw.In my case transistors Q-830 and Q-421 needed resolder loose joints.These components are mounted on flat aluminium heat sink strips located sligtly left of center of the circuit board.Also blobed bit of silicone into base hole and foot of alu.heat sink to support it.
Apr 15, 2009 | Toshiba 36A50 36" TV
Toshiba 36A42 36'' T.V.
A common cause is a failure in the one of the scan amplifiers or on the high voltage section. It is also possible to have a power supply fault that will give this error message.
Jerry G.
Dec 14, 2008 | Toshiba 36A42 36" TV
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
Red Power Light Comes On, but nothing else.
Fuse inside if blowen will sometimes show a power lamp but no current to the tv
Aug 20, 2007 | Toshiba 36A40 36" TV
Power but no picture on a toshiba 36a61 36" tv
could it be the socket wirings was loose check and retightened. more help....dnlsabangan@yahoo.com
Nov 09, 2006 | Toshiba 36A61 36" TV
Toshiba CX36G60 36 inch tv has blinking light
Most likly it is a power regulator problem, and had nothing to do with the Xbox. These sets are common for this BUT it is unfortainate, that most likly you will be surprised when you take the set into the repair shop, on the cost of the repair. In a set this old, I would not evenm invest in an estamate charge, as Im quessing its going to cost between 225 to 300 to repair. Good Luck
Oct 07, 2006 | Toshiba CX36G60 36" TV
Toshiba 36A50 36" TV Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
