Master
- Posted on Sep 07, 2009
Re: Water will not drain. Could be a food blockage....
If the water doesn't drain from your dishwasher, check these:
- Drain line/air gap--A clog in this part is the usual
reason that a dishwasher doesn't drain. Remove the drain line to clear
any debris from the hose or hose connection at the household drain line
connection. Reattach the hose before starting the dishwasher again.
- Pump--You can reach the pump from inside the
dishwasher. Remove the lower rack, spray arm and support. Look for an
impeller, a device that spins around and forces water through the spray
arm. This is the wash impeller and beneath it is the drain impeller
that pushes the water into the drain port. Replace it if found
defective or worn out.
- Drain valve/solenoid---The drain valve may have a
solenoid with lever that sticks or frozen and prevents the dishwasher
from draining. Free up the solenoid and lubricate the lever.
- Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
- Motor---Check it if turning or working.Turn the rotor
manually to see if stuck and free it up. Replace if defective, it is
not serviceable.
